Thread: Help With Battery/Alternator
    Nov 2010
    St.Ives
    Default Help With Battery/Alternator
    So i was driving to MK the other day and got 3 miles down the road and the battery light came on...thought ok well i'll keep going and hopefully the battery will charge.
    5 miles further and i lose powersteering so turned round and came back, another 5 miles and i lost ABS and traction control then a mile later everything in the dash went dark and even the needles got stuck.
    I have read on here its likely to be the alternator so i'm about to get a jump start so i can get it to the garage but wanted to test the alternator voltage.
    Where do i need to put the multimeter points, i know nothing about cars lol.
    Car is a Vectra Elite CDTI 150 2.0 55 plate.
    On the battery terminals when the engine is running. Red to +VE and black to -VE, you should see 13+ volts when the engine is running but to be honest it sounds like your alternator is U/S without the need to test it.
    Nov 2010
    St.Ives
    18V then dropped to 16v then car cut out
    Getting recovered now and its probably fubar'd the battery too.
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Yip - knackered alternator and its prob goosed the battery also!
    Nov 2010
    St.Ives
    yep estimated cost £480 :'(
  1. battery or alternator?
    By Swedge in forum Electrical & ICE (including SatNav)
    Last Post: 23rd August 2012, 08:33
  2. Alternator or Battery
    By Jamie in forum Electrical & ICE (including SatNav)
    Last Post: 21st December 2011, 21:30
  3. Battery, alternator or something else?
    By djr69uk in forum Vectra C / Signum Car Chat
    Last Post: 6th December 2010, 16:19
  4. Alternator or battery?
    By RobW in forum Electrical & ICE (including SatNav)
    Last Post: 29th November 2010, 22:20
  5. Alternator or Battery?
    By callist in forum Electrical & ICE (including SatNav)
    Last Post: 4th October 2010, 20:24
