Thread: Vectra CDTI SRI 150 rev problem
    May 2011
    Hampshire
    Default Vectra CDTI SRI 150 rev problem
    My vectra has been running great until the other day, it seems to have lost alot of power. It runs okay for about 15 miniutes then it goes into limp mode and will not seem to rev over 3000. Any ideas?
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Quote Originally Posted by dan912 View Post
    EGR Valve or the dreaded Swirl flaps..
    What year and millage?
    Does it missfire at all?
    May 2011
    Hampshire
    Nope it doesnt misfire at all and its 2006 with 79k ok the clock.
    West
    Have you got a malfuncion light showing?
    Without having the codes read... it's just guess work.
    The usual suspect however are:
    EGR
    Vac system
    Swirl bar
    MAF
    May 2011
    Hampshire
    Theres no malfunction lights showing at all, ive got an op-com being delivered today so will run today and post my results.
    May 2011
    Hampshire
    I have now ran the op-com and found 3 codes, one of whice was the egr valve which i have now removed and cleaned and after resseting the fault codes has not come up again. The other two are:
    P0234-5B Boost Pressure Control Circuit Positive Deviation
    P0621-01 Generator Lamp "L" Control Circuit Malfunction
    Any ideas on how to fix these two?
    May 2011
    Hampshire
    I have also changed the boost pressure sensor and has not made a difference.
    West
    May 2011
    Hampshire
    Thanks for the reply, im going to check all pipes this weekend and if need be remove the turbo and give everything a good clean. When driving i can always hear a slight whistling noise, could this possibly indicate a split in a pipe somewere?
  1. Help!!!Vectra 05 1.9 SRI CDTI power problem!
    By sohail1989 in forum Vectra C / Signum Troubleshooting
    Last Post: 18th November 2012, 00:32
  2. vectra cdti injector problem...
    By betrayed in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2012, 02:11
  3. my bro`s 120 cdti sri vectra oil problem
    By chris6409 in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2010, 12:13
  4. vectra 150 cdti....turbo problem?
    By trigger in forum Engine & Drivetrain
    Last Post: 29th May 2009, 14:53
  5. Problem with Vectra 1.9 CDTi 150
    By Manni2375 in forum Engine & Drivetrain
    Last Post: 18th March 2007, 17:21
