Thread: PLEASE Fitting fuel pipe help
    Mar 2011
    Shropshire
    Default PLEASE Fitting fuel pipe help
    Im having a right mare at mo, i changed fuel filter about a month ago and snapped one of the end clips because it would NOT come off, even when the filter was off the car i still cannot remove the clip.
    Anyway, as the pipe is pretty much made to fit i had to put a new pipe on and as i didnt have the clips on at the time i dubilee clipped them on, its lasted for over a month now id say but it popped off other day under the high pressure, so ive got some other pipe now with the clips on but having a right nightmare trying to feed it through, its just too tight, is there an easier way of doing this? Please someone tell me im in a right stress
    Mar 2011
    Shropshire
    Its a 52 plate 1.8 16v petrol by way. And its the pipe from fuel filter to pump
    uk
    Can you take a picture of the pipe and the end of the filter so i can understand whats required.
    Regular Member john506's Avatar
    Mar 2011
    Wirral
    I may be getting this completely wrong but if your trying to push the new pipe onto the thread like connection but it won't go all the way on, try dipping the end of the hose in boiling water for a few seconds to soften it, when cooled it will go back to stiff.
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    as above,
  1. cdti fuel feed pipe
    By ronnie63 in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd July 2012, 14:50
  2. Decat pipe fitting?
    By Adam8220 in forum Diesel Engine related
    Last Post: 21st July 2012, 18:09
  3. Oil leak from oil return pipe after fitting turbo
    By tommytonguedj in forum Engine & Drivetrain
    Last Post: 2nd August 2011, 15:00
  4. Scorpion pre cat pipe, fitting tips needed
    By Governor in forum Diesel Engine related
    Last Post: 11th March 2011, 11:56
