Thread: Code 0302
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Trim : Irmscher Elite
    Engine : 3.0 CDTI
    Default Code 0302
    Hi guys. Been having probs with th judder at less than 2000 revs on the V6 CDTI. Did the pedal test a moment ago and got 0302 - cylinder 2 misfire detected.
    Someone direct me in the right direction please. It's been suggested by people on here that a likely culprit is the injector. Any advances on that?
    Cheers in advance
    Blantyre
    Read on another forum mate that similar issues suggests the coil pack
    I dont know much about your model so dont shoot me down
    LINK HERE
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Cheers for the heads up mate. I'll try his method of looking at the ignition advance readings and take it from there.
    north east
    misfire on diesel normaly points to crank shaft sensor. does it only happen when hot and does it sound like its going to stall at idle eg junctions ?
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    [QUOTE=spennny;1539703]Read on another forum mate that similar issues suggests the coil pack
    Coil pack on a diesel ?
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    [QUOTE=TimTay;1539871]
    Quote Originally Posted by spennny View Post
    Ha Ha. I i'm not mechanically minded and not sure what all the parts are called but that would explain why there weren't any on ebay for the V6 CDTI. I did notice on the other forum that his was a petrol though
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Quote Originally Posted by roswell View Post
    Just been out for a drive now and the misfire didn't re occur. I had a crank shaft sensor issue on my cdti 120 and didn't have a misfire. The only thing that happened was that after about 3 months of spanner light it just wouldn't start.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    normally the injector's go faulty might be a idea to have it removed and tested ....these engines do have a igniter pack fitted on the top left of the engine these can play up but normmaly all injectors will be missing .....
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Mine sometimes does something similar. Example, sometimes judders under light acceleration (only hot), and would drop the rpm to 500 (hunting idle, a bit like this http://www.youtube.com/watch?v=62EPBVFmWSc&NR=1 sound starts at about 0:35) if I press the clutch after the engine was braking (exiting a multi story car park for example). Sounds great, but should I worry? Picks up the idle if I rev it.
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Quote Originally Posted by benny View Post
    Cheers mate. Someone suggested i got in touch with a diesel specialist to get that done, so i'm off to find one.
  1. No cd code
    By Mickey76 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd February 2013, 18:44
  2. Code 0300 & 0302 on 2.8 Signum elite
    By chunkey_monkee in forum Engine & Drivetrain
    Last Post: 7th January 2013, 19:54
  3. Error code reading and code readers
    By Ben50n in forum Engine & Drivetrain
    Last Post: 27th August 2012, 16:43
  4. 0302 - cylinder 2 misfire detected
    By kristian in forum Engine & Drivetrain
    Last Post: 26th September 2011, 19:28
  5. Car Pass - Result! Key Code & Radio Code
    By mxt in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2010, 13:01
