Thread: How to bleed 2.0dti
    Apr 2009
    manchester
    Default How to bleed 2.0dti
    What is the best method to bleed a 2.0dti.
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    towing it lol or get a hand primer there good too
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by piker john View Post
    What have you done to it? Just a fuel filter or something more?
    Apr 2009
    manchester
    Will be fitting a fuel injection pump,will also fit the original edc so it wont need coding.
    lincolnshire
    crack the pipes off one by one , while cranking it over OR air;ine down the fuel tank to pressurise it and try starting it or what Bangty has already suggested
    East Midlands
    Or buy one of these and bleed it through..
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    Quote Originally Posted by macdad View Post
    where is it to be fitted?
    Sep 2010
    in a box
    tow it mate save you a starter moter and o DONT USE easy start ffs
    Sep 2010
    in a box
    Quote Originally Posted by Al 22 dti View Post
    i fitted mine near filter but it never started with just this i use to prime it with this (do it till it went hard) then i towed mine allways started
    no of this trying to fit a starter after you burned it out lol
  1. Clutch Bleed
    By mat_splat in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2012, 19:36
  2. Bleed valve on a 2.0t
    By tomo41 in forum Petrol Engine related
    Last Post: 26th June 2011, 12:50
  3. how to bleed the clutch
    By vectra3.2dave in forum Vectra C / Signum Car Chat
    Last Post: 30th May 2010, 14:26
  4. LCD bleed
    By Guyver1 in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2010, 18:49
  5. Any one recommend a bleed kit?
    By n_hudson in forum Suspension, Wheels & Brakes
    Last Post: 1st November 2009, 00:33
bleed vauxhall2.2 dti
