Thread: New HU and amp wiring
    Apr 2011
    People's Republic of Plymouth
    Default New HU and amp wiring
    I've just finished wiring up my new headunit and active sub, all works great but ive had to use the permanent live wiring for the sub remote on and for the HU itself...which isnt perfect I know! I've read a bit on here about having to use the cigarette lighter for an ignition live? How do you go about wiring that up, as my only one is next to the gear stick? (my wiring skills generally suck...)
    Is it possible to reset the clock on the dash now I've upgraded the HU? Seems to be stuck on midnight
    Quote Originally Posted by chris198 View Post
    remove the ashtray and you will see the wires for the cigarette lighter , just wire your wire into the black wire on the cig lighter
    and
    no you cant adjust the clock , you will need to put the original hu back in it for it to automatically set
    Apr 2011
    Thanks for the reply!
    Hmm thought that'd be the case with the clock, guess I'll have to start wearing a watch then
    Does the trim around the lighter just pull away and then you drop the remote cable down the back of the heater unit?
    [QUOTE=chris198;1539385]Thanks for the reply!
    Does the trim around the lighter just pull away and then you drop the remote cable down the back of the heater unit?[/QUOTE]
    exactly
    remove the plastic surround for the gear lever ( just pulls ou )
    remove the ashtray inner
    then just remove the ashtray outer
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    Just disconnect your battery and connect it at midnight. Clock time will be right but date will be wrong. Done this my self as binned my old head unit.
    Apr 2011
    Cheers for the replies guys, give it a go next week I think.
    TimTay; my clock doesnt even move off of 00:00 - how do you get it moving, ill connect it as you say at midnight if i can!
    Nov 2010
    BRECHIN
    Da Ken bout that, my clock was wrong after rippin the cd40 out so just disconnected the bat and reconnected at midnigt then it starts at 00.00 and works as u would expect it to. Don't know about kick starting it lol
  1. Tow Bar Wiring Help Please
    By countduckula55 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd July 2012, 10:55
  2. Wiring help please?
    By Danwells72 in forum Electrical & ICE (including SatNav)
    Last Post: 13th March 2010, 23:13
  3. I need help with wiring.
    By gibbon7000 in forum Electrical & ICE (including SatNav)
    Last Post: 8th June 2009, 00:41
  4. Sub Amp Wiring kit
    By nick-v2.2 in forum Electrical & ICE (including SatNav)
    Last Post: 9th April 2009, 22:32
  5. Tow wiring
    By amiddleton in forum Electrical & ICE (including SatNav)
    Last Post: 14th May 2008, 07:57
