Thread: Bulb Failure notification
    Regular Member brentmeister's Avatar
    May 2011
    Ockendon
    Default Bulb Failure notification
    I recently had the BC enabled on my Vectra - thanks to a forum member ( ).
    I had a bulb failure recently and only got a symbol come up in the dashboard. I thought I would have got a message in the display of the stereo like this
    Attachment 42636
    Is this only available on certain models, as I don't wish to trouble the forum member again -as I was very grateful for what he did.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    the Checkcontrol is not available on all screens, and have to be seperate enable in the screen via tech2.
    May 2011
    Ockendon
    Thanks for that reply.
    I thought that the check control had been enabled and that only the washer bottle had been " unchecked "
    Engine : 2.2 Direct
    In the screen you can only enable or disable checkcontrol.. its in the UEC where you have to disable the washer bottle sensor..
    May 2011
    Ockendon
    anyone else have any ideas please
    Regular Member dansri's Avatar
    Jul 2010
    doncaster
    mines comes up with a pic like that, tells me wich light to check. 53plte sri 2.2 dti
    May 2011
    Ockendon
    any one else please
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    Is that the standard pic for bulb failure and such like? Because mine is a little more graphic than that. If that makes sence.
    Engine : 2.2 Direct
    Have you checked to see if checkcontrol is enable.. instead of asking just for more?
  1. Bulb Failure Detection
    By Dhrideruk in forum Vectra C / Signum Car Chat
    Last Post: 20th June 2011, 17:19
  2. Bulb failure.
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 31st August 2010, 10:47
  3. Bulb Failure Notification
    By WeDesign in forum Electrical & ICE (including SatNav)
    Last Post: 1st August 2010, 15:35
  4. bulb failure light
    By paulzvectra in forum Vectra C / Signum Car Chat
    Last Post: 15th July 2009, 20:03
  5. bulb failure
    By jbr in forum Electrical & ICE (including SatNav)
    Last Post: 27th May 2006, 17:11
