Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: power steering issue
    NULL
    Default power steering issue
    Hi, I think there is an issue with my power steering on my 2.8t
    when its idling if i turn lock to lock it sounds like its whining a bit so i checked the power steering fluid and it appears to be frothing up.
    Any ideas?
    thanks
    james
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by jamesworts View Post
    Any ideas?
    thanks
    james
    Sounds like the fluid wants topping up or replacing - level could be so low that air is getting in hence the frothing. Wants sorting quickly or you could knak the pump.
    WGAF#5
    iirc electrofluidic power steering (or Electric Hydraulic Power Steering ) self bleeds on full lock hence the noise and the bubbles
    NULL
    2.8 don't have ehps matey. (at least this one doesn't) its a standard belt driven pump.
    james
    WGAF#5
    really ...are you sure .... they do in the VXR ??
    i appreciate the suspension is different as its got IDS but the steering rack would be the same
    and listed on the specification of the face lifted Signum as well
    http://www.vauxhall-cars.co.uk/range...all_signum.php
    Mechanical
    • Lowered and uprated VXR sports suspension
    • Interactive Driving System Plus (IDS2-plus) with Continuous Damping Control
    • Sport Button:- When Pressed improves the responses of both the steering, suspension and throttle giving the driver crisper initial acceleration and sharper, more direct turn-in when cornering.
    • Front ventilated disc brakes - 345mm diameter
    • Rear ventilated disc brakes - 292mm diameter
    • Pagid brake pads
    • Front and rear brake callipers in blue
    • Electro-hydraulic power-assisted steering (EHPS)
    • Lightweight MacPherson strut front suspension and multi-link rear suspension with gas-pressure dampers
    mine has it
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    All Vectra C and Signum have EHPS...
    NULL
    OK. you want to argue it out????
    What is the black tank on the left hand side next to brake fluid?? i'll give you a clue it says Power steering fluid only on the cap.
    The next clue IT HAS A POWER STEERING PUMP DRIVEN BY A BELT!
    next clue. cannot connect to EHPS module - probably because it hasn't got one!!!
    DOH!!!
    I'm not a plant engineer for nothing!! (granted i asked for help, but only cos i hadn't come across power steering fluid frothing up, especially in an excavator!)
    NULL
    oh and according to EPC EHPS pump is fitted on vectra-c/signum EXCEPT Z28NEL and Z28NET !!
    Part number for Z28NET/L 12842029 clue in the description PUMP, ASSY., POWER STEERING, WITH PULLEY
    Once again
    Nov 2010
    East Midlands
    Trim : design
    DOH!!!
    I'm not a plant engineer for nothing!! (granted i asked for help, but only cos i hadn't come across power steering fluid, especially in an excavator!)
    Hey - My excavator has power steering fluid and EHPS - Sorry
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Might be a good idea to put more facts up when you first post up then we would not be playing a guessing game lol
  1. power steering issue
    By Baldwin in forum Vectra C / Signum Troubleshooting
    Last Post: 26th October 2012, 21:58
  2. Power Steering issue?
    By madvortex in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2012, 19:47
  3. Power steering issue
    By MIAMI in forum Vectra C / Signum Troubleshooting
    Last Post: 21st September 2010, 21:05
  4. power steering issue
    By myelite150 in forum Engine & Drivetrain
    Last Post: 8th September 2010, 14:54
  5. Another Power Steering Issue 2.2 DTI Sri
    By l33byt in forum Suspension, Wheels & Brakes
    Last Post: 23rd January 2008, 13:20
vectra z28net power steering pump
