Results 1 to 10 of 15
Thread: Wobbly Gear Knob
    May 2011
    BEDFORD
    Default Wobbly Gear Knob
    Hi Guys,
    Im Steve and am a new member after just buying a Mint 2.2 SRI pre facelift.
    Ive noticed one problem with the car since purchase which I am keen to get resolved.
    When in Gear, the Gear Lever / Knob seems to have excessive play and can be moved about an inch from left to right, this is surely not normal ??
    What could be the problem ? Is there an easy fix ?
    Goes into gear fine with no sounds etc !!!
    Any Help appreciated...
    Sep 2010
    Leyland
    Same happened to mine mate, however when I selected reverse, the entire top of the knob flew off.......along with the spring!
    This may not be the official way, but with the knob removed, I put a blob of glue in the knob, then a small knock downwards seemed to resolve said problem!
    May 2011
    BEDFORD
    Default Wobbly Gear Lever
    Thanks for your reply.
    I meant to say its the whole gear lever that moves, not just the knob lol
    South West
    Pop the gaiter off. On the stick there is a shaft which comes out to the right about 1/2 way down which locates into a grey plastic arm.
    On the end of the shaft there should be a small plastic cup. Chances are on yours the cup has either come out and is floating in the area at the bottom of the center console or it has just fallen apart.
    Dont know if you can get this as a spare from Vx, but if you can it is likely to be pretty cheap
    http://www.vectra-c.com/forum/showthread.php?t=134261
    Here ya go, You can see the plastic cap in the arm, and also removed in the pictures
    May 2011
    BEDFORD
    Thanks for your help, will have a look in the Morning to see if this is the problem.
    north east
    Quote Originally Posted by Di frost View Post
    Currently waiting for mine to pop off its moving about 5 mm and clicks down when I use 135 and pops up for 246 every change is Click pop .. click pop click pop ..
    Regular Member djr69uk's Avatar
    Midlands
    my fix worked and it didn't involve glue. i just put some rag around the spline and whacked the knob back on - just bulks it out a bit and stops it working lose. it's been solid and on for well over a year since.
    May 2011
    Ilkley
    Mine too pops off bad design of a knob if you ask me, I don't fancy glueing it on incase it needs to be removed anytime. So just simply turned it around slightly and tapped it on. Ok the gears show off angle but we should all know where the gears are. And dont know if it's had any effect on my gearbox for banging it on everytime it came off but car is in garage for Gearbox :-(
    May 2011
    BEDFORD
    Thanks Aidi, Had a look to see if the part was missing, but no luck, my gear assembly looks totally difernent to the pictures in your post.
    Any other ideas anyone
    Regular Member CH-VECTRA-ELITE's Avatar
    Frimley
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 140000
    And here's me thinking i was the only one, it's not helpful when changing gear and the knob goes flying into the passenger floor area. I normally whack it back down but it still pops off, don't want to glue it, maybe blu tack will do the job or might use the rag trick like djr did with his
  1. show me your knob (gear knob)
    By justin32 in forum Bodywork & Interior
    Last Post: 10th October 2011, 19:18
  2. Wobbly Knob
    By ChrisBilly in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2011, 12:23
  3. Wobbly Gear Stick
    By Aidi in forum Engine & Drivetrain
    Last Post: 28th January 2011, 21:33
  4. Wobbly gear knob
    By paulvectrac in forum Engine & Drivetrain
    Last Post: 27th June 2010, 10:49
  5. Play in my knob gear knob lol
    Last Post: 16th June 2010, 08:20
