Thread: Looks like on stilts
    Apr 2011
    Corby
    Default Looks like on stilts
    Hi all,
    Car was knocking from the front drivers side, took back to garage as under warranty ANC was diagnosed with broken coil spring which was replaced all good apart from car now seems to be on stilts at the front :0( will it settle or was it looking lower due to broken spring?
    As it's an Sri with 19" snowies it looked very squat before but now not looking so good ATM hope it settles! Measuring now it's 4 fingers width from tyre to arch, sure it was lower prior to 1 spring replacement.
    Admin plasma's Avatar
    On the Forum
    310 Post(s)
    Engine : 150
    Mileage : 74000
    Possibly replaced with a pair of springs meant for a non lowered sports chassis.. Find out the replacement part no.s they fitted for you and then let me know... as well as your reg no.
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Apr 2011
    Corby
    Did look at springs and only one looks replaced as would expect lop sided if 2 different springs?
    On the Forum
    310 Post(s)
    Engine : 150
    Mileage : 74000
    normally springs are always replaced in pairs,???
    Apr 2011
    Corby
    Pretty sure only broken one was replaced :0(
    On the Forum
    310 Post(s)
    Engine : 150
    Mileage : 74000
    Give them a call tomorrow and find out.
    Apr 2011
    Corby
    Just put note in calendar to do exactly that :0)
    I know the guys at the garage that carried out the job so will call 1st thing for stats.
    Regular Member Jezzy's Avatar
    S.E
    Quote Originally Posted by plasma View Post
    It'll be a pattern part rather than a GM one, so the part number won't tell us much.
    Apr 2011
    Corby
    rang the garage this morning and they said they only replaced one and it was for the sri suspension (lowered), reading more on here I see people think theres is too high at the front as standard anyway so perhaps now mine has it new spring it actually at the right height...
    Time for some Eibachs maybe
    Full Member Big Sig's Avatar
    On a car that size and weight its best practice to replace in pairs. A good garage would of told you that.
  1. Replies: 15
    Last Post: 14th July 2011, 08:50
