Thread: if tyres on wrong way and a spacesaver, lot of road noise???
    Regular Member Jow20's Avatar
    Sep 2010
    Leeds
    Default if tyres on wrong way and a spacesaver, lot of road noise???
    My snowflakes ive put on have firestone firehawk tyres on and i cannot work out if ive put them on wrong way, if.they are on wrong way wud this cause more road noise?? There is no directional arrows! And i also need a new tyre so have a space saver on, wud this add to the road noise?? Thanks
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    Depends if there directional tyres, if not and if there asymetric they will be marked inside - outside
    Jun 2009
    South Coast
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    what tyres are they?
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    Nov 2010
    BRECHIN
    Would effect water dispersal if incorrectly fitted aswell. Got a pic?
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by Jow20 View Post
    If there is no directional arrow I would imagine that they can run either way. The spacesaver should be run at a pressure of 60psi so you will probably get a lot of noise ie rumble from this tyre + it is only designed to 'get you home' and shouldn't be used as a substitute for a normal tyre, as well as having a max speed of around 40mph.
    Sep 2010
    Leeds
    They are 235/35/19 y rating. Sorry no pic as i use my phone to post. Maybe it is the space saver then it does look really low. spacesavers tiny!!! Car looks silly wi it on, but will be gettin anotha tyre on the snowie tommoro anyway. And i mite change em round see if it helps. I thought all tyres was made to go the same direction, and it was just which side u put it on to affect the rotation been correct!?
    Oct 2007
    Shropshire
    Also if you drive on the space saver for long you will start to wear the inside of the other tyre and then need two..... I would not drive more than 100 miles on it if I could help it...
    Full Member Big Sig's Avatar
    As your not able to post pics and clearly have no idea about tyre fitting, when your getting that other tyre fitted, ask the fitter
    Jun 2009
    South Coast
    lol was after the make and model of the tyre etc not the size, that we could google it and look at the tread pattern to advise you on its rotational dirtection..
  1. wrong road speed
    By davecj in forum Engine & Drivetrain
    Last Post: 11th December 2012, 11:15
  2. Wheel Alignent or New Tyres? Noise Noise Noise
    By lostdog in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2011, 13:29
  3. Do cheapo tyres = more road noise...
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2009, 13:18
  4. Wrong tyres?
    By kipster in forum Vectra C / Signum Car Chat
    Last Post: 30th July 2008, 19:16
  5. Replies: 81
    Last Post: 21st June 2008, 17:19
