Thread: vacuum pump leak... :(
    Sep 2010
    ipswich
    Default vacuum pump leak... :(
    hi iv noticed oil on the right side of engine just behind vacuum pump.
    so i took it of (only 4 screws holding it) cleaned it up and used some sort of heat resistant sealant on all the joints.
    and.... its still leaking.
    i dont wanna buy new vacuum pump does anyone know is it posible to buy new o-ring for it , or at least how to mend it proper ?
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    is it a y20dth or y22dtr if it is you can get the seal seperate also might be worth checking rocker cover gasket isn't leaking as well.
    Sep 2010
    ipswich
    sorry forgot to mention main thing its 2003 2.0 dti im pretty sure its vacum pump, cause iv cleaned engine and i can see where its comeing from.
    Sep 2010
    ipswich
    where could i get it from, dont like to use main VX dealers.... they rip me off usually... you go to buy one part and end up with stuff you dont really need
  1. Vacuum pump reliability
    By Richard.roberts in forum Engine & Drivetrain
    Last Post: 19th April 2012, 20:42
  2. 2.2dti vacuum pump leak
    By Al 22 dti in forum Engine & Drivetrain
    Last Post: 3rd April 2011, 15:07
  3. vacuum pump
    By Dougb in forum Engine & Drivetrain
    Last Post: 30th June 2010, 22:41
  4. Vacuum Pump 1.9 cdti 120
    By mark230678 in forum Parts for sale
    Last Post: 3rd July 2009, 21:39
  5. EML - Vacuum Pump ?
    By matiny2k in forum Vectra C / Signum Troubleshooting
    Last Post: 30th July 2008, 20:53
vectra c 1.9cdti sealing the vacuum pump
