Thread: Condenser or Radiator?
    Sep 2010
    Leyland
    Default Condenser or Radiator?
    Ok, so I have a coolant leak on my Veccy. I've traced the leak to the bottom left of a radiator (as you look at the car). I've checked some other posts and it appears to be a common problem (leaking from where the plastic and metal joins).
    So, set on ordering and fitting a new radiator, I go to order it. Then I get confused......is the leaking article the condenser or radiator? How do I tell?
    Looking at both from above, its the one nearest the engine...
    Quote Originally Posted by Di frost View Post
    Coolant tastes bitter, put a small amount on your tonque then spit it out
    This will confirm it is coolant, rather than water
    If the condensor has failed it just leaks gas and you won't notice
    It can however change colour and collect water
    The condensor is nearest the bumper
    The radiator, which is much larger, sits behind it nearest the engine
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    condensor is at the very front, so sounds like the raditator.
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    put a egg in it
    Sep 2010
    Leyland
    Thumbs up
    Marvellous, cheers guys. Radiator ordered....cheaper than the condensor too!
  1. Intercooler radiator removal without water radiator
    By Whosane in forum Vectra C / Signum Troubleshooting
    Last Post: 5th December 2012, 15:48
  2. AC condenser
    By signum_rob in forum Vectra C / Signum Car Chat
    Last Post: 25th July 2012, 11:59
  3. A/C condenser
    By Derek Mc in forum Engine & Drivetrain
    Last Post: 22nd August 2011, 19:59
  4. A/C condenser
    By xaviroller in forum Bodywork & Interior
    Last Post: 8th July 2009, 11:56
  5. AIr con radiator and condenser for sale
    By ghostrider in forum Parts for sale
    Last Post: 23rd July 2007, 06:00
