Thread: EGR valve
    Aug 2010
    Derbyshire
    Default EGR valve
    Just a quick one for those who have cleaned there EGR valve.
    CDTi 150 '06' plate.
    Will I get a dash warning light come up if I disconnect then reconnect it.
    Have read on these forums others have had the light which some say goes out after a few starts, is this true?
    Mick
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    If reconnected, the light will go out.
    CO.Durham
    i took mine off cleaned it put back on (never had key in) and i got no lights at all.
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    just remember to plug it back in before you start it, or you'll end up with the spanner light when the ignition is on..
    Regular Member Pete B's Avatar
    Malvern
    Quote Originally Posted by neilrobinson1988 View Post
    Same with me, I've done it (and the boost sensor) twice without issue. The second time (about 8k miles ago), I also replaced the valve/manifold gasket with the Fiat restricted one without any issue. Time to remove the boost sensor again to see how clean it is.
    May 2011
    Thumbs up
    Me too clean mine on Saturday morning following the how2 on the forum and hey no spanner lights thank god.
    Aug 2010
    Derbyshire
    Thanks for the replies.
    Done my boost sensor, wasn't too bad.
    Also I think the EGR valve may have been renewed before I bought it last year.
    It looks cleaner than the rest of the engine, so hoping it's not too bad, seems a bit down on power when pulling away.
    Mick
    Nov 2010
    doncaster
    which gaskets do i need to get to get the fiat restricted one are they square or oval ones seen both and where from i have 2007 1.9 cdti 150 thanks
    Malvern
    Quote Originally Posted by fjaimo10 View Post
    You just need the larger square one for the 150 CDTi, the one that goes between the valve and inlet manifold mount point.
    If you get the latest one from Fiat, you get a compound gasket with sealing material round the outer edges of both sides of the restrictor plate so it's a one piece part.
    Nov 2010
    doncaster
    can you get the restrictor plate from them too
  1. Brake servo Valve (one way valve)
  2. Replies: 6
    Last Post: 29th July 2012, 13:52
  3. Egr valve, swirl valve problems etc..
  4. EGR valve / Swirl valve
    By SwavGav85 in forum Engine & Drivetrain
    Last Post: 5th January 2009, 17:17
  5. EGR valve and Swirl Valve
    By TUX-VECTRA in forum Vectra C / Signum Troubleshooting
    Last Post: 6th July 2007, 00:43
