Results 1 to 3 of 3
Thread: ABS Fault
    Jun 2009
    Middlesbrough
    Default ABS Fault
    Hi
    Just had ABS fault investigated by local garage and it said front drivers side ABS sensor fault.
    My question therefore is, if there was a fault with the wiring leading to drivers side ABS sensor would that show up as a fault on the drivers side ABS sensor diagnostic check or would it show as a wiring fault somehow. In other words can the fault system on the vectra distinguish a fault in a sensor from one on the wiring leading to a sensor or isnt it that clever?
    Thanks in advance
    Paul
    WGAF#5
    in a word ...no
    the sensor being faulty, or a fault with the wire COULD induce the same displayed fault ... there still has to be some level of diagnostic check via a technician to determine the cause .. this could be as siimple as disconnecting the sensor and running a meter over it to see if its short/open circuit or metering the wires for high resistance
    HTH
    regards
    Dez
    Jun 2009
    Middlesbrough
    thank for your reply, i was clutching at straws i suppose.
    Lad who did the diagnosis on the sensor told me this afternoon that he put meter across sensor and it read 0.5 ohms instead of 1.5 ohms.
    New front bearing needed i guess.
    Paul
  1. Not sure if this a fault or not.............
    By carperjake in forum Electrical & ICE (including SatNav)
    Last Post: 7th November 2012, 20:39
  2. Replies: 15
    Last Post: 9th July 2011, 22:19
  3. ABS fault...
    By DNS in forum Suspension, Wheels & Brakes
    Last Post: 23rd June 2011, 03:05
  4. Another Fault
    By khile in forum Vectra C / Signum Troubleshooting
    Last Post: 20th March 2010, 18:57
  5. swirl valve fault or egr valve fault
    By learoy69 in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2008, 09:04
