Thread: spanner light on poor starting?
    liverpool
    Default spanner light on poor starting?
    hi all. the light has been on for a week or so intermitantly,however
    it is now on all the time.only symptoms are poor starting.turns over great but wont fire up,well not for a few try's anyway.it always used to start on the button.i'm mechanically inept so any ideas would be gratefully appreciated.someone told me glow plugs? but would that trigger the spanner light? thanks in advance
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    may be glow plugs,but the best way is to have codes read,glow plugs do put fault light up,what engine have you got,try turning on ign without starting up untill glow plug light goes out,turn off ign and back on again straight away untill glow plug light goes out,do this 3 times and start engine on the 3rd try.if it starts sraight away you have plug problems,but without the codes it could be quite a few things.
    liverpool
    sorry should have said,its a 1.9cdti(150)
    Sep 2010
    doncaster
    i had the same problem, and i got the garage to change my glowplugs and diesel filter and that cured it...
    Jezz
    Engine : 1.9 CDTi
    Measure the resistance of the glow plugs
  1. poor starting
    By tomo610 in forum Engine & Drivetrain
    Last Post: 15th January 2012, 19:21
  2. poor starting
    By kmx racer in forum Engine & Drivetrain
    Last Post: 26th July 2011, 22:51
  3. 2.2 dti poor starting
    By riauba in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2010, 13:47
  4. Poor Starting
    By st2malo in forum Engine & Drivetrain
    Last Post: 4th March 2010, 16:09
  5. Spanner Light, No Code, Poor MPG - WHY?
    By markluk in forum Vectra C / Signum Troubleshooting
    Last Post: 17th March 2009, 13:48
