Likes Likes:  2
Thread: Brake pipe replacement
    Jun 2009
    Middlesbrough
    Default Brake pipe replacement
    Hi
    I know there are alot of threads on this subject but I have some further questions on brake pipe replacement.
    Car failed MOT today on brake pipes, front and front to rear.
    I think I can replace them myself but what I arent sure of is do the brake pipes simply leave the ABS control module and go straight to each wheel without going through any pressure equalising valves or anything else.
    I have looked on TIS and cant find anything showing the full brake pipe layout.
    Thanks Paul
    Regular Member RobW's Avatar
    Tain - Easter Ross
    An old school mechanic told me once that if you clart the brake lines in grease, they cannot inspect them and will usually just pass it. Not allowed to wipe the lines.
    I know it is not a suitable 'fix' if they are corroded but quite a handy hint if it is true.
    No idea on original question, sorry.
    Aug 2010
    Stoke on Trent
    mine failed a few years back for having greased brake pipes as he claimed he couldnt inspect them.
    Regular Member signumboy's Avatar
    Edinburgh/outskirts
    Engine : 2.0 Ltr Turbo
    Mileage : 38000
    I am almost certain they just go to the cylinders after leaving the ABS unit as i had mine done last year and garage showed me the job they had done as they know Im on this site and i could not see any other connections .....
    Edinburgh/outskirts
    Mileage : 38000
    Quote Originally Posted by RobW View Post
    Not ideal if your brakes do fail though .... these checks are for road safety and personnel safety ....not a good idea to take chances
  6. Likes AndrewGuy liked this post
  7. #6
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    They pipes all go directly to the rubber flexi pipes in each wheel arch, however........the nearside rear goes over the fuel tank and is a complete pain to do
  8. #7
    Jun 2009
    Middlesbrough
    Default brake pipe replacement
    thanks for all your replies, will do pipes at the weekend.
    paul
  9. #8
    Jan 2014
    Leicester
    Trim : LS
    Engine : 1.8 petrol
    Hi,
    The pipes must be able to be visually inspected for the MOT test! End of story, if they cannot be inspected because they were hidden by grease or underseal the test person can lawfully request that they are cleaned off and then the car re-presented or worst case a fail certificate will be issued.
    The easiest method of repair is to inspect the brake lines and cut out the corroded sections then graft in new pipe (Copper or Kunifer because they do not corrode and are easily shaped) using a jointing kit which is readily available from Ebay. Some are made so they can be be used for insitu on car use, the 'plier' type, a bit more expensive though being the easiest ones. Just make sure that you buy the correct tool (and pipe etc) of either imperial or metric.
    The sections of pipe which are in the engine compartment or above the fuel tank usually do not corrode because they are protected by their locations. I have used this method many, many times and the cars I have applied this repair to all then passed the test. Typical cost of a repair kit including the pipe and ends is around £28.00.
    Hope that helps.
  10. #9
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    128 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    If all brake pipes must be visible to the MOT inspector, then every single vectra-c and signum should have failed every MOT test, as the pipe which runs over the tank cannot be inspected, so I can't really agree with your first statement.
    In my experience, the section above the tank is usually the first to corrode to the point of leakage. I've had two brake failure's - one on a vectra and one on a signum. In both cases the pipe ruptured where it runs above the fuel tank.Thankfully in both cases I noticed the pedal creep to the floor whilst moving in slow traffic and could still stop by pumping the pedal. Had this happened at higher speed the consequences could have been very bad. I'm not sure why they corrode here - it must be something to do with condensation caused by temperature variations and the thermal mass of the liquid volume in the fuel tank.
    2006 Signum Design+ 1.9 CDTI and 2007 Signum Elite 2.8 V6 Turbo
    1.9 CDTI Diagnostics and tuning, remote remapping for distant members
    PM for more info.
    Remaps for Insignia 2.0 CDTI up to early 2012 *New* Remaps for 2.8 V6 Turbo
  11. #10
    Full Member petrolcan's Avatar
    Dec 2015
    Watford
    18 Post(s)
    Trim : Elegance
    Engine : 1.9 CDTI (120)
    Quote Originally Posted by Teapot View Post
    Nonsense. As long as you could keep going you'd be fine.
    I had a front brake failure on a motorbike once whilst coming off the M1. Slowing from 70 by hammering down through the gearbox and prodding the useless rear drum brake was interesting.
    Didn't die though.
    2006 Signum 1.9 CDTi (120)
    EGR mapped out & DPF removed. Mildly breathed upon.
  12. Likes Teapot liked this post
  1. Brake servo pipe Help (Plastic Pipe)
    By Mark2.2 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2014, 15:41
  2. Off the shelf DPF replacement pipe?
    By lee gsi in forum Diesel Engine related
    Last Post: 22nd March 2013, 13:28
  3. Brake pipe replacement ns near petrol tank
    By david106 in forum Vectra C / Signum Car Chat
    Last Post: 16th July 2012, 21:02
  4. where can i get replacement i/c pipe??
    By vectra_c_wannabe in forum Vectra C / Signum Car Chat
    Last Post: 11th December 2010, 17:22
  5. Help finding replacement pipe
    By green-m in forum Vectra C / Signum Troubleshooting
    Last Post: 4th September 2009, 21:27
how to change metal brakr pipe on a vectra estate
vectra brake pipe replacement
vectra 2004 brake pipes
brake hose vectra c
front brake pipes for vectra c
vectra c rear brake pipes
Vauxhall vectra C rear brake pipes
vectra c brake lines
vectra c complete brake pipe line
how much to get a brake pipe repaired on a vauxhall vectra c
vauxhall vectra front to rear brake pipe
what size of brake pipe unions do I need vectra c
vectra c front rubber brake pipes
how too change brake line on vauxhall vectra 04
vectra c 1.8 brake lines
vectra c rear flexi brake replacement
Vauxhall vector C 1.8 brake servo pipe
vectra c brake pipe leak
vauxhall signam break pipes
vectra c copper brake line
vectra c copper brake lines for sale
diameter of brake pipe vauxhall vectra
vectra c brake pipe replacement
what fittings are on vetra brake pipes
changing Vauxhall vectra felront brake pipes
