i got myself a tc switch because i could really do with being able to turn my tc off at times but as is my luck when i fitted it it didnt work, is it a case of programing or do wires need to be run for it to work, and if so has anyone done it ?
sadley no ......but i'll have it off of you lol ...
It's missing wires. Use the search function you will find lots of threads. You will also find a el schematics for the button.
Kristian
68 Diplomat-A 46S
95 Vectra-A C20NE
07 Vectra-C Z19DTH
do you know if its possible to run the wires and ive had a look but cant ind uch about running wires
Kristian
68 Diplomat-A 46S
95 Vectra-A C20NE
07 Vectra-C Z19DTH
My VXR has the plug in the dash...But nothing happens when I push the switch and press the button...
nice one sulten, where are the connections attached, i take it in the blue plug?
Apparently need a little wiring...
Wait till Brentwood Penfold, theres an easy test you can do at the abs plug under the bonnet to see if its switchable...
Kristian
68 Diplomat-A 46S
95 Vectra-A C20NE
07 Vectra-C Z19DTH
