Results 1 to 10 of 14
Thread: Oil change, pain in the a###
    Aug 2010
    Derbyshire
    Default Oil change, pain in the a###
    Well just completed an oil change on the gearbox and engine, Signum 150 CDTi.
    Gearbox oil change was a breeze thanks to the 'How to' without removing the battery tray.
    The engine oil, well what a stupid place to put the filter, and that under tray, had to take it all off.
    They certainly don't make it easy these days for the home mechanic working on the drive.
    After reading also about how some have had problems removing the drain plugs, mine thankfully came undone ok with no drama.
    Anyway all done now and hopefully a smoother gear change will be a good result.
    Mick
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    its so much more satisfying when you do it yourself though dont you agree
    Jan 2010
    Perkinsville, County Durham
    Trim : Sri nav
    Engine : Z19dth
    Last time I had my tray off I cut along the hinge, separating the flap from the tray then drilled pairs of holes each side of the cut. Then simply zip tied the holes together. Any time you need to take the flap off, just cut the ties.
    Regular Member Jezzy's Avatar
    S.E
    Quote Originally Posted by MickAP View Post
    You're welcome. lol
    Aug 2010
    Derbyshire
    Yeah, that's why I like doing it, and you know it's been done properly with the correct oil etc..
    Trouble is now my old bones are not what they used to be, I'm suffering today with all that grovelling about under the car. Got the EGR to take off now and clean, think I'll have a rest day
    Mick
    Regular Member AlexGSi2000's Avatar
    May 2011
    Liverpool
    My Vectra came without the under-tray, complete with a rounded sump nut.
    Took me 3 hours with various tools... grinder... easy outs, only to find the new sump nut was too small - resorted to using an exhaust lambda sensor to plug it.
    Oil filter I attacked from the top of the engine reaching down - that was overtightened.
    Gearbox oil I found to be a doddle - the drainplug was already loose, so saved me the hassle. I had to remove the battery tray to access the fill point, but wasnt too time consuming as someone had already disconnected the cable guides & left the glow plug relay hanging down towards the bottom of the engine.
    Are you VXR Enough
    13 Post(s)
    lazy git lol
    Aug 2010
    Derbyshire
    Quote Originally Posted by AlexGSi2000 View Post
    I never bought any replacement gearbox/sump plugs, reused the existing one's. Would have been a different story had I mashed em up though.
    There are no washers originally fitted to the fill or drain plugs anyway on the gearbox, which is surprising.
    Mick
    Jun 2011
    Where is the sump nut for vectra c
    Edinburgh
    Bottom of the sump lol
  1. OMG In Pain!!
    By Happy Girl in forum The 'Off Topic' room
    Last Post: 9th August 2011, 14:09
  2. What a pain!
    By Maverick in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2009, 21:26
  3. I'm in pain....
    By sonic in forum General Chat
    Last Post: 10th March 2008, 22:27
  4. Oh the pain!!
    By izonoky in forum Detailing and Car Care Discussion
    Last Post: 6th November 2007, 00:04
  5. What a pain in the ****
    By The Gas Man in forum Styling
    Last Post: 13th March 2006, 20:16
