Results 1 to 10 of 16
Thread: Oil light coming on and completly losing power
    Jan 2010
    Bracknell
    Default Oil light coming on and completly losing power
    Hi im hoping someone might know whats the problem. ive taken it to my mechanic and they have had a few guesses but nothing they are sure about as its not showing any fault codes. its a 1.9 16v cdti sri and when driving for no apparent reason the oil can light with a spanner comes on and then all the power goes. It wouldnt even pull away at a roundabout and gets quiet scary as the mrs uses the car with the kids mainly so want to get fixed asap. Its fine if you switch it off and on again afterwards.
    Any help greatly appreciated
    Jan 2010
    Bracknell
    Oh yah forgit to say its 04 reg and no excessive smoke coming from it
    north east
    petrol / diesel ?
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    When was last serviced?
    Jan 2010
    Bracknell
    Its a diesel. and yeah will be due a servuce in about 2000 miles. could it be as simple as that
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    It would be first place I'd start mate
    Whilst doing it clean egr valve and map sensor
    Regular Member djr69uk's Avatar
    Midlands
    does it drive ok whilst it's cold? or happen when it's cold? or both?
    Jan 2010
    Bracknell
    Ok cool ill try that. cheers and to djr its hard to say cos it rarely gets up to temperature. Its happened after about 5 miles both times so should be warmish. it drives completly finenormally and fine after you switch it off and on again.
    Does anyone know what oil us best to use
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by WDUK2005 View Post
    Vauxhall fully synthetic's good and cheapest especially if your in the trade club
    Midlands
    if the spanner light is thrown up then surely the ECU would log some kind of fault? it even logs historic faults... i think it's worth seeing if you can get someone with opcom/vauxcom to read the codes... ?
  1. Loss Of Power And EML Light keeps coming on
    By rocksteady in forum Vectra C / Signum Troubleshooting
    Last Post: 24th August 2011, 09:44
  2. Oil light coming on and completly losing power
    By WDUK2005 in forum Engine & Drivetrain
    Last Post: 24th May 2011, 21:57
  3. Alternator light coming on and loss of power steering
    By fairhaven in forum Electrical & ICE (including SatNav)
    Last Post: 12th January 2009, 18:06
  4. Help Car Keeps Losing Power
    By gregc in forum Engine & Drivetrain
    Last Post: 20th August 2008, 01:07
  5. sri 150 losing power
    By marky2027 in forum Engine & Drivetrain
    Last Post: 25th July 2007, 20:09
