Results 1 to 2 of 2
Thread: Oil light coming on and completly losing power
    Jan 2010
    Bracknell
    Default Oil light coming on and completly losing power
    Hi im hoping someone might know whats the problem. ive taken it to my mechanic and they have had a few guesses but nothing they are sure about as its not showing any fault codes. its a 1.9 16v cdti sri and when driving for no apparent reason the oil can light with a spanner comes on and then all the power goes. It wouldnt even pull away at a roundabout and gets quiet scary as the mrs uses the car with the kids mainly so want to get fixed asap. Its fine if you switch it off and on again afterwards.
    Any help greatly appreciated
    Regular Member LADmachining's Avatar
    Hampshire
    Are you sure it's not the light of a car with a spanner over it?
    If it is this light, there should be fault codes stored in the engine ECU which will point them in the direction of the fault.
    Oil can with a spanner sounds more like a 'service due' indicator. This wouldn't affect the power output or running of the car.
    From your description, and knowing the 1.9 engine, you could have a problem with the EGR valve.
  1. Loss Of Power And EML Light keeps coming on
    By rocksteady in forum Vectra C / Signum Troubleshooting
    Last Post: 24th August 2011, 09:44
  2. Oil light coming on and completly losing power
    By WDUK2005 in forum Engine & Drivetrain
    Last Post: 28th May 2011, 23:15
  3. Alternator light coming on and loss of power steering
    By fairhaven in forum Electrical & ICE (including SatNav)
    Last Post: 12th January 2009, 18:06
  4. Help Car Keeps Losing Power
    By gregc in forum Engine & Drivetrain
    Last Post: 20th August 2008, 01:07
  5. sri 150 losing power
    By marky2027 in forum Engine & Drivetrain
    Last Post: 25th July 2007, 20:09
