Thread: Crankshaft pulley replacement
    West Sussex
    Default Crankshaft pulley replacement
    Just over a year ago I had my crankshaft pulley replaced with a pattern part. The construction of the new pulley is different and ever since the engine has vibrated and sounded rough (er) at idle. Also since then I've had a squeal from the aux belt, especially when it's cold, and a really loud squeal when under pressure (i.e. in drive or with the air con switched on) but fine when it's past 10,000 rpm.
    I've tried all sorts of belt lubricants, the only thing that worked for a few minutes was chalk!
    I've decided to have a go at starting again, new pulley (genuine part) belt and maybe tensioner, although that was replaced last year. Apart from getting the stretch bolt out of the pulley, is there anything else that I need to know before I start? I want to give it a go because I can't stand the thought of giving Vauxhall dealers my hard earned money!
    Any advice appreciated.
    Phil
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by Croxley View Post
    Phil
    Mine sounds a bit rough when I go over 9,500 rpm
    PRESTON
    Is your Veccy the 2.0dti? If so i will watch this thread with interest to see how you go on. The wifes Frontera 2.2dti uses the same bottom pulley and has suffered the same noise/vibration at idle since it was replaced with a pattern pulley back in Feb. At the time it had a new tensioner and Gates aux belt, which squealed like a stuck pig, so changed that for a VX one and the squeal has gone, but the vibration is still there. I too believe its the pattern vibration damper. I undertsand the genuine part is around £175 from VX.
    West Sussex
    Quote Originally Posted by barney490 View Post
    Sorry I should have said. Mine's the 2.2 dti auto, so same engine (I think)
    I did have a genuine belt fitted but it still squealed. Annoyingly, I didn't have any squealing or vibration until the pulley was replaced. I plan to start this over the weekend, weather permitting!
  1. Crankshaft Pulley
    By 123ashleyp in forum Engine & Drivetrain
    Last Post: 5th March 2010, 12:37
  2. crankshaft pulley
    By djsoundman in forum Engine & Drivetrain
    Last Post: 20th November 2009, 12:05
  3. Crankshaft Pulley again!
    By ANDY H137 in forum Vectra C / Signum Car Chat
    Last Post: 31st May 2009, 14:34
  4. Yet Another Crankshaft Pulley!
    Last Post: 13th January 2008, 00:27
vectra c crankshaft pulley
removing crankshaft pulley for frontera 2.2dti
how to replace vectra diesel crank pulley
vauxhall vectra bottom pulley
how to change a crankshaft pulley on a vectra c 2008
vauxhall vectra c crankshaft pulley
vectra c crank pulley
crankshaft pulley change on frontera 2.2dti
how to replace crank pulley astra 2.0dti
vectra.c crankshaft.pulley
vauxhall vectra cdti 120 crankshaft pulley removal
vauxhall 2.2 sri crank pulley
vauxhall vectra 2.0 dti idler pulleys
vauxhall vectra c 2.0dti crankshaft pulley
my 2010 astra diesel engine bottom pulley keeps breaking
zafira 2006 crank pulley replacement
vauxhall frontera crankshaft pulley
vauxhall insignia bottom pulley bolt
how to unscrew vectra c crankshaft pulley
vauxhall vectra 2.0 dti crankshaft pulley
vauxhall vectra crankshaft pulley.1.9 new design
how to change bottom crankshaft pulley vauxhall vectra
opel zafira technical specs crankshaft pulley
dti replacement crank pulley
vauxhall zafira 2.0 dti crankshaft pulley removal
