Results 1 to 10 of 27
Thread: Vectra 1.9CDTI(120) Black Smoke Exhaust.
    Notts
    Smile Vectra 1.9CDTI(120) Black Smoke Exhaust.
    Hey all,
    When starting the car cold, I get the typical puff of white smoke from the exhaust, but when I start driving, just inside the turbo range I get a puff of black smoke, bad enough that I can see it from my rearview AND my sideview mirrors.
    If I gun it and hammer the accelerator the puff of smoke is purely embarressing!
    its a 54 Reg, 51k miles and due for a service. But it seems that the black smoke has gotten ALOT worse in the past couple of months.
    Im a newbie with cars and would love to do whatever investigation I can, I heard somewhere about the possibility of split pipes. I have had a good look around the engine bay but couldn't actually see anything of fault (but lets be honest, I dont really know what I am looking for!)
    Tonight I am going to stick a video of the exhaust blow so you can see, then if there is 'somewhere' I should look I'll stick pictures on so you can annotate them ... ha
    I've spoken to a mechanic and he just said 'Diesels smoke...' yeh, ok, I get that, but this is a hell of alot more than just some 'smoke'
    Hopefully you fine chaps can help me out.
    north east
    Black smoke is normaly, shortage of air flow ( air filter need changing?? ) or intercooler plumbing, a known week spot on the 1.9 cdti`s is the bolt that holds on the dip stick wearing a hole in the intercooler pipe, if thats not your cause you need to start hunting out the leak good news is just look for the filthy black area and you have thesource of your leak.
    Notts
    hey, thanks for the answer. Sorry it has taken so long to get to you!.
    I have uploaded images of my engine bay Here
    Could anyone be as kind as to show me the places to look? take the pics and scribble on them in paint if you like!... the smoke has gotten alot worse!.
    I have changed the air filter but it made no difference. Im a total newbie to motors so the engine bay is a guessing game for me
    Oct 2010
    London
    See that big fat hose which is going into the right hand side of the engine? Check that for any oily residue on it and for splits, have somebody rev the engine up and see if you can see a split open up or you can hear hissing, if so that is your culprit!
    Could also be the EGR which recirculates exhaust gas back into the engine (nutty EU rules) they can get gunked up and stick open or closed causing lots of smog!
    Regular Member Craig1985's Avatar
    harwich essex
    Mine also done the when my intercooler hose split.
    Notts
    thanks for the answers all. Me and my mate decided, with the help of the guides, to have a go at cleaning the EGR valve and the Boost Sensor. The boost sensor was caked and the EGR valve had seen better days.
    cleaned them but still got the same issue, in half an hour going to check the intercooler pipe (the big black one) properly
    Oct 2010
    London
    Cleaning those two items can make a world of difference from what I have read so definitely was worth trying.
    Let us know about the boost hoses!
    Notts
    where are the boost hoses?
    I was told to check these in another post : THESE
    but all looks ok, the thinner pipes are a little bent but not leaking.
    I am going to clean the throttle body tonight, does anyone know of ANY other things I can check? are there any other pipes I should check for leaks?
    So far:
    Boost Sensor
    EGR Valve
    Going to:
    Throttle Body
    Any help would be appreciated, im running out of ideas!
    PRESTON
    Possibly it's a split intercooler (known issue on vectra). They normaly go on the bottom right side as you look from the front of the car. The signs to look for are a big bulge in the intercooler on it's underside and dirty oil stains around the back of the bumper, lower right as you look at it. Also check the thin vac hoses that run from the vacuum pump to the turbo control valve on the front panel, upper right side. They perish and split causing the turbo not to boost properly, which can cause black smoke.
    Notts
    had the throttle body off and cleaned it. Its still smoking, not as bad though! each thing I clean seems to help it out a little.
    Quote Originally Posted by barney490 View Post
    Will try and take a look at the intercooler tonight. As for the vac hoses, I have ordered a fresh set from the bay for a few quid so will fit them when they arrive. Im going through pretty much everything apart from getting it to a garage to be checked over.
  1. Black exhaust smoke on high revs, EGR light on, rough idles - 1.9 cdti 150 diesel
    By bananas in forum Vectra C / Signum Troubleshooting
    Last Post: 5th September 2012, 13:25
  2. 1.9cdti black smoke/smell
    By dubsrus in forum Engine & Drivetrain
    Last Post: 16th November 2010, 17:58
  3. Vectra C (2004 1.9 cdti) black smoke, no turbo, air leak HELP!
    By baldieone in forum Vectra C / Signum Troubleshooting
    Last Post: 29th July 2010, 13:51
  4. Black smoke from exhaust - YAHOO ANSWERS
    By 123ashleyp in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2010, 11:16
  5. Two recordings of my exhaust and black smoke
    By george1987 in forum Diesel Engine related
    Last Post: 14th June 2010, 17:28
vectra 1.9 cdti black smoke
vectra black smoke from exhaust
vauxhall vectra diesel black smoke
vectra c black smoke
vectra c diesel black smoke
vectra c cdti black smoke
opeal insignia has a leak on the heavy pipe coming from the ingean on the right under bumper
pic of air flow system on vectra c z30dt
astra 1.9cdti black smoke
vauxhall vectra 19 cdti black smoke
08 vectra 1.9 cdti 150 lossof power and black smoke from exhaust
2007 vectra tdi exhoust
vectra 22 black smoke no power
vauxhall vectra 1.9 cdti black smoke
how to fix opel vectra 2.0 black smoke
zafira 1.9 too much black smoke1.9 cdti boost pipevauxhall zafira 1.9 cdti 120 black smokevauxhall vectra 1.9 cdti wont rev black smokewill a dirty turbo make a vectra 1.9cdti black smokeblack smoke on a vauxhall vectra 1.9 tdc but drives fine ivectra c cdti black snokeblack smoke vectra dieselblack smoke vauxhall vectra 2004
