Thread: Help needed vectra C 1.8 [elecs]
    May 2011
    Rhyl
    confused Help needed vectra C 1.8 [elecs]
    Can anyone help or addvice me.
    Some days car starts fine other days to get it to start I have to turn my lights on and off before it will started any one had this problem?
    Sep 2009
    Audley STAFFS
    I think you need to give more info, like,,, does the car turn over but not start,, give as much info as you can, as having to turn your lights ON then OFF before it will start is a very strange one.
    May 2011
    Rhyl
    some days it turns over other days you have to put lights on then it turns over.also the hole dash goes off ie speedo,petro then comes on again
    Sep 2009
    Audley STAFFS
    check main fuses under the bonnet one maybe loose also check battery leads ect are clean and tight.
    scotland
    get battery checked out too !
    May 2011
    Rhyl
    fuses fine and battery new I think its some think to do with the egnition and lights some were the wires must meet.
    Car started fine today but second time wouldnt start untill I put lights on,then the car started
  1. Replies: 14
    Last Post: 25th December 2012, 17:48
  2. new battery in but now starter does not turn all other elecs appear OK bat shows 12.5v
    By danjsc1 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd December 2012, 23:29
  3. Replies: 6
    Last Post: 23rd December 2012, 21:16
  4. My vectra help needed
    By 123ashleyp in forum Vectra C / Signum Car Chat
    Last Post: 9th July 2010, 19:22
  5. vectra 2.0t help needed
    By roc in forum Engine & Drivetrain
    Last Post: 16th March 2009, 22:08
