Thread: Tech 2 question.
    CO.Durham
    Default Tech 2 question.
    Does only vauxhall have it or can I buy it if so how much and where from?
    I ask as I'm looking into elecs in the back and a few other mods.
    Cheers neil
    Glasgow
    All GM garages have it and you can buy it, thinks its about £2k.
    Edinburgh
    CO.Durham
    What does the cheap kits of eBay do?
    Full Member
    South West
    Quote Originally Posted by neilrobinson1988 View Post
    Probably screw your car up, so you would end up going to a Vx garage to get it sorted correctly.
    Unless you are willing to spend big bucks for genuine diagnostic/programming tools, then IMO you're playing with fire.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I know quite a few members have the ebay version including me and it works fine.
    Does not do what the full Tech 2 does but its still very useful. I don't think I have heard any members say that it has screwed up their car unless someone says different. TBH the Dealers can do a good job of screwing your ECU as many members on here will agree with
    Glasgow
    The ebay ones are useful if you know the basics and technical terms or if you have worked in a garage environment. There has been a handful of people at least that have came on here and have "pressed things" just to see what it does and caboom they have wiped coding from ecu's, it can be dangerous and expensive in the wrong hands. Then there is the dodgy cracked versions on ebay which will let you try and program things and let you wipe the old settings get to the stage of coding and give you an error code because theres a corrupt file for example.
    It all leads to a dead car which needs recovered to a dealers for things to get re-programmed.
    Full Member vxpenfold's Avatar
    Nov 2010
    sittingbourne,kent
    Vehicle : Vectra Hatchback
    Trim : Life(well it was)
    Mileage : 166000
    the only way you wil screw you car up is if you dont know what youor doing and tbh thts easier to do with tech 2 than other devices tbh
    South East Region ARO And Resident Diesel Head
    Owns: 2005 Vectra Life Hatchback 1.9 CDTI 150 Mods: Too Many !!!
    CO.Durham
    Iv worked for Nissan when I go to the garge to get codes read I normally do it just use there laptop, they don't use tech 2 tho, all they can do is read and reset but the garage is good 45 mins from where I live now.they guys that use them do they work on diesels just some say they don't.
    Edinburgh
    You can buy canbus code readers that will let you read/reset codes but jot do any programming.
  1. Please help with a quick tech 2 question
    By david.mann8 in forum Vectra C / Signum Car Chat
    Last Post: 2nd December 2012, 19:28
  2. Tech 2 HIDs question...
    By Leemarksmith in forum Electrical & ICE (including SatNav)
    Last Post: 2nd October 2012, 09:26
  3. Tech question for the IT gurus...
    By macdad in forum The 'Off Topic' room
    Last Post: 11th July 2012, 19:50
  4. Quick question for the tech peeps
    By sy_uk in forum Vectra C / Signum Car Chat
    Last Post: 20th January 2009, 23:36
  5. Tech 2 Question
    By CDTi Mike in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 18:24
