Thread: back end flicks out
    exeter
    Default back end flicks out
    when i go around a bumpy corner the back end feels like it want to flick out and bounces around . does anyone have any ideas what it is
    Regular Member jimmyred's Avatar
    Dec 2010
    Southport
    sounds like rear upper contol arms or possibly shocks? Is it like if you hit a bump going round a corner the back wheels seem to skip a few inches sideways? Mine does this and the control arms were an advisory at recent MOT. The bouncing suggests shocks tho...
    You can check for play in your rear control arms:
    With the wheels on ground, reach over the wheel and grab the back edge of the tyre at 12 o'clock. Tug on it towards you. If there is any movement you will hear a slight clanging/knocking noise. This indicates worn bushes in the rear upper control arms.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Did all the replies to your first thread about this not give you the answer then?
    spoons
    Guest
    Quote Originally Posted by reeseandellie View Post
    Sounds like your dampers need replacing
    New Member jim_h's Avatar
    May 2011
    cowdenbeath
    not sure if thats how mine felt, a bit like trying to pilot a blancmange round a corner!
    changed the rear shocks and its made a massive difference (one failed MOT) easy enough if you have axle stands, and some torx sockets (think its E18 top, E20 bottom) two bolts out she comes just support the weight of the hub with a jack!
    hth
    Jim
    exeter
    just been under the car and found that both of the rear spring had snap and when i went to put the new ones on somemuppet at the garage has cross threaded one wheel nut and done another up so tight it had snaped in half . now i got to sort that out some how ? any ideas !! , thanks for the advice
  1. Battery Light flicks on for a Moment when engine is switched off
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2013, 23:32
  2. Replies: 0
    Last Post: 5th July 2012, 23:27
  3. Help, the back ligth and back door not working after using hanger
    By joacom in forum Vectra C / Signum Troubleshooting
    Last Post: 19th April 2009, 15:24
  4. Milau Trip - back seat report...WE'RE BACK!!!!
    By Duncan in forum General Chat
    Last Post: 30th September 2007, 12:53
