Thread: Interior Light
    Apr 2011
    Berkshire
    Default Interior Light
    Having a problem with my Interior light, when I open the doors it doesn't come on, I can either have the light on or I can have the light off,
    as there are two buttons on it, when i have the drivers side button pushed in the light is off constantly, when i have neither of the pushed in the light is constantly on.
    Anybody got any ideas?
    Regular Member bulletproofpanda's Avatar
    Sep 2010
    Nottingham
    Have you have a play with the switches in the door frame that turn on the light? Its late and that is the best explanation I can make !!
    11 Post(s)
    Quote Originally Posted by bulletproofpanda View Post
    Have you have a play with the switches in the door frame that turn on the light? !
    There are no switches in the door frame of the Vec-C / Signum. They're integral to the door stay or door latches.
    11 Post(s)
    Quote Originally Posted by MattHD View Post
    One of those buttons switches the light off altogether. IIRC that's the one on the RH side of the panel.
    The other one is to switch the light on and off manually (the other button needs to be on for this to work).
    As the interior light is staying on, it would suggest the fault is with one of the switches in the door.
    Is the light on the dash indicating a door is still open when they're all shut? Have you got the display that shows each individual door, or the one that just shows a light regardless which door is open?
    Apr 2011
    Berkshire
    I have the display that shows which door is open etc, and doesn't say any are open when closed
  1. interior light
    By jamiedvvt in forum Bodywork & Interior
    Last Post: 19th November 2012, 17:47
  2. Interior Light - 4th light switch blank ?
    By Woody in forum Electrical & ICE (including SatNav)
    Last Post: 12th November 2012, 23:44
  3. Interior Light Issue - Light & Button Illumination?
    By Leemarksmith in forum Electrical & ICE (including SatNav)
    Last Post: 7th November 2012, 23:36
  4. URGENT:Glovebox Light/Interior Light Fuse
    By Hendry in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2011, 09:13
  5. interior light
    By chrosty in forum Bodywork & Interior
    Last Post: 6th April 2011, 23:06
