Are they the same between engines or are there different versions?
Different versions - take off the plastic cowling and you'll see the CIM with the "ident" code written on it; you need one with the same code.
Is it a straight swap forthe same model or a tech2 / opcom session
Tech2
How many different ident codes are there? I guess it's 2 letters?
Found one that matches mine on fleabay for £55 all in. Just need to arrange fitting and tech2 when it arrives.![]()
