Thread: 2.2Dti
    Regular Member Gazz's Avatar
    May 2011
    N.Ireland
    Default 2.2Dti
    Recently bought my Signum 2004 2.2 DTi, got the software updated under warrenty and all filters and oil was changed prior to purchase so has anyone got this engine remapped? if so how does it fair? is it worth it? I have also asked my Mechanic to look into Decatting it, so again is it worth it? whats the advantage?
    Anything else you may know about this engine type would be great as am only learning about it
    Milton Keynes
    Quote Originally Posted by Gazz View Post
    The cheapest way to more power is the airbox mod (it's free - just do a post search) and if it's done over 60k miles, get the inlet manifold cleaned out as it will be full of gunk from the EGR system. Clean up the boost sensor at the same time. I just did both of these and the difference was huge. Main things to look for are split rubber turbo boost pipes and chafed through vacuum pipes. These will affect performance and put the car into limp mode (spanner light) usually when you put your foot down at low revs in 4th or 5th gear. It's expensive to do a remap just for another 20 bhp or so. Better off doing the airbox mod and inlet manifold first. If the engine is breathing properly, the 2.2DTI is pretty quick in standard form.
    Regular Member smirnoff sri-dti's Avatar
    Apr 2011
    London
    Thumbs up
    i agree
    got Vectra C with same engine and done air-box mod with Piperxross panel air filter
    + de-cat and egr valve cleaned its fast enuf around town
    don't forget u didn't bought your car to be a Schumacher
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    It's a shame the dti was killed off in favour of the less desirable 1.9 fiat unit. If the had made the dti common rail it would have been an awesome engine.
    The 2.2 is pretty pathetic in standard form tbh but a tuning box or remap can turn them into a rather torquey beast.
    Air box mod is a waste of time and a regularly changed Vx air filer is more than adequate, change it every 10k instead of the recommended.
    De-cat is a great idea but I recommend just knocking the insides of you existing box out, it's cheaper and if they should change the mot any time soon it still looks standard
    Another thing to look into is a straight through exhaust of some sort. it's a diesel so don't be affraid to remove silencers, to noise won't increase that much
    The 'best' re-map for the dti comes from eds and can see up to 160bhp and 270lb ft of torque. downside is that because of the hybrid ecu on the fuel pump, if the pump should fail then you'll lose the map
    Don't be put off by a tuning box either, I have a steinbauer pbox fitted to mine and that gives me 155bhp and 281lb ft of torque, which is nice
    Hope that helps somewhat
    Regular Member dansri's Avatar
    Jul 2010
    doncaster
    i have 2.2 dti sri vec 53plate 84thou., done the mentioned above,airbox mod,new silicone vac pipes cleaned egr ect and a good service runs sweet pretty nippy too. considering the de cat by smashing guts out ov it but not sure if i dare lol.
    May 2011
    N.Ireland
    Iv seen some of the Remaps done and in some cases you get 158bhp with 6-8 more mpg, so that would be handy, again looking at all options, ill start with the easier items such as cleaning inlet manifold etc, the Decat can be done easy enough, Friend can do it for me, keep the Cat in the shed and if MOT changes ill always have it to reattach.
    Whats the steinbauer pbox like? worth it?
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    Quote Originally Posted by dansri View Post
    Do it, Its not to hard to do. look....
    http://www.vectra-c.com/forum/showthread.php?t=133377
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    If mine was to go wrong tomorrow i'd be right on the phone to buy another one, I love it
  1. Will this fit my 2.2dti
    By sberrow in forum Vectra C / Signum Car Chat
    Last Post: 5th May 2011, 20:25
  2. Vec c 2.2dti sri
    By SUBEK in forum Vectra C / Signum Car Chat
    Last Post: 6th March 2011, 20:54
  3. Eml 2.2dti
    By Gortreck in forum Engine & Drivetrain
    Last Post: 3rd March 2010, 20:23
  4. its not too bad for a std 2.2dti.............
    By david.aka.judas in forum Gallery
    Last Post: 16th March 2009, 08:58
  5. 2.2dti, not GM?
    By prm in forum Vectra C / Signum Car Chat
    Last Post: 20th June 2007, 00:32
