Thread: Oil issues????
    Feb 2011
    Plymouth, Devon
    Trim : SRi soon VXD
    Engine : 1.9 CDTi
    Year : 07
    Mileage : 65k
    confused Oil issues????
    Hi guys,
    You all seem to know more than i ever do so its always easier to ask. Ive got a 52 Gsi and now and then the oil level light comes on, i pull over, give it 5 mins to drop into the sump, check the oil level and all is fine..... i thought id buy some oil just to be safe and when i went to top it up there was a wierd white gel/oil substance on the top of the oil filler spout as if the engine is throwing some crap up at it???
    Any idea's and should i think about getting it checked? it only had a major service and obviously oil change 4k miles ago.
    cheers guys
    gaz
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    White gunge in the oil is water getting in. If it's only a very small amount it's fairly normal from condensation especially if you only do short runs in the car, if there's quite a bit of it, you may have a head gasket gone.
    11 Post(s)
    Quote Originally Posted by gaz_gsi View Post
    Is your dipstick the correct length?
    Mine wasn't on my previous 2.2 Vectra.
    http://www.vectra-c.com/forum/showthread.php?p=1238251
    As for the mayo, (Ian that is)
    Feb 2011
    Plymouth, Devon
    Trim : SRi soon VXD
    Engine : 1.9 CDTi
    Year : 07
    Mileage : 65k
    cheers guys... its only small bits in the oil filler cap, no smoke or anything and certainly no loss in power!?! its going in to have some work done at the end of the month so prob get them to look at it as they're replacing the 2nd bank coil pack.....
    north east
    Id clean the oil breathers out, do an oil change and get a new oil pressure switch and take it from there.
    Are you loosing any coolant at all ?
    Feb 2011
    Plymouth, Devon
    Trim : SRi soon VXD
    Engine : 1.9 CDTi
    Year : 07
    Mileage : 65k
    Quote Originally Posted by roswell View Post
    work has been done, slight leak on the rocker cover gasket which was leaking a lil bit of oil but no coolant loss..... seeing how this work goes if it comes back ill get it sorted, thanks
    didnt the gsi have the issue with the longer oil filler neck causing more condensation thus making it seem like mayonaise in the rocker
    i think most people removed the long neck and the problem went away
    Full Member Big Sig's Avatar
    Quote Originally Posted by marktaylor View Post
    Exactly that Mark!
    Don't worry, as long as its just in the filler its normal. The filler is in the cold air stream so water condenses in there and mixes = Mayo.
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    just remove the filler neck and put the cap directly on the rocker cover. problem solved
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    mark is spot on
  1. EGR Issues
    By signum_1.9 in forum Engine & Drivetrain
    Last Post: 30th June 2012, 11:51
  2. GID issues
    By kensbey in forum Electrical & ICE (including SatNav)
    Last Post: 11th May 2011, 17:46
  3. Issues!
    By Danwells72 in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2011, 01:13
  4. Would I have any issues with...
    By n_hudson in forum Vectra C / Signum Car Chat
    Last Post: 24th August 2008, 19:07
  5. mp3 issues with cd 70
    By jeff_g in forum Electrical & ICE (including SatNav)
    Last Post: 6th June 2008, 22:27
