Thread: VXR 255 or 280
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    Default VXR 255 or 280
    Hi guys as above how can you tell which is which, is it only declared on the logbook ?
    Glasgow
    Whats the regy year? 07 and before its likely a 255. You can tell by looking on the drivers door pillar but im not sure what the power is in kw. Someone else should be able to tell you for sure what the door pillar should say.
    New Member Tmd's Avatar
    May 2011
    UK
    Both Z28NET engines but later more power. Not really answering your question am I ...... I'll get my coat
    Regular Member PORKBALLS29's Avatar
    Epping
    On the drivers side door plate it will say 208kw if its a 280 bhp or 186kw if its the 250 bhp model. Other than that the only other way is to take the air box out as the 280 has an extra hole in the air box. HTH Alan.
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    Cheers Howard
    VOTING UKIP IN AVELEY
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    Quote Originally Posted by Daywalker View Post
    Cheers Howard
    so your getting really tempted then ???
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    Gonna keep a look out but wanted to know how to tell difference want to get the 280 one if im going to get one
    Regular Member graham a's Avatar
    hull
    good man
    Regular Member VXR_DV's Avatar
    South Coast
    Drivers door plate should look something this.
    Anything other than Arden Blue is the wrong colour, too
