Thread: Aerial seal fitting wot do I ave to remove to get to the nut
    Worksop
    Default Aerial seal fitting wot do I ave to remove to get to the nut
    As above Wots needed to removed to get the roofing lining down so I can fit a new one
    Regular Member eaglepva's Avatar
    Up North
    Their is a how to for this somewhere m8
    Regular Member paul.sessions's Avatar
    leighton buzzard
    i removed the parcel shelf climbed inn and yanked on the lining
    Regular Member farley2708's Avatar
    antrim n.ireland
    17mm spanner,is the rubber all perished?
    mines was,it was letting water in,lying in the boot wheel well,10mins the job was done,aerial led just clips apart,only had problem i had was the rear washer feed pipe,a bit awkward to get pushed together again,if you do have to change the aerial base,a wee bit of black silicone on the underside of the base before you attach it back onto the car,should give you a perfect seal
    hth
    Worksop
    Quote Originally Posted by farley2708 View Post
    hth
    were d o i start to undo the bits that hold up lining
    Worksop
    all done easy job 20mins max
  1. sat nav aerial seal
    By john norris in forum Electrical & ICE (including SatNav)
    Last Post: 2nd August 2014, 21:59
  2. Dab aerial seal?
    By azacbr6 in forum Bodywork & Interior
    Last Post: 16th January 2013, 10:54
  3. Aerial base seal gone
    By paul wingnut in forum Electrical & ICE (including SatNav)
    Last Post: 10th December 2011, 18:06
  4. Replies: 0
    Last Post: 8th September 2011, 12:29
vectra c aerial nut
how to remove vectra c aerial
vectra c roof aerial seal
changing an aerial base gasket on a vectra
vectra c remove roof aerial
https:www.vectra-c.comforumshowthread.php138273-Aerial-seal-fitting-wot-do-I-ave-to-remove-to-get-to-the-nut
