Thread: Fitting Thermostat 120 CDTI Help !!
    Regular Member deanos's Avatar
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    Default Fitting Thermostat 120 CDTI Help !!
    Got everything undone but im stumped on how to take off the metal tube that's attached to the bolt at the bottom of the stat ?
    Any ideas folks
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    Uploaded with ImageShack.us
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    Anyone ?
    Regular Member greza1066's Avatar
    Nov 2010
    barnsley
    Vehicle : vectra c
    Trim : cdti sri
    its an absolute t**t mate. did mine 6 months ago. there are another 2 bolts/nuts somewhere round the back of the engine. think they are under the egr valve. i took off most of the bits on the right rear side of the engine to get into these. oh and there is a metal braid hose to undo from the back of it as well.
    ireland
    this brings back memorys,the words what sorta c..t designed that,
    i cut the bracket off as didnt want to go disturbing the egr cooler gaskets and god noes what else,once brackets cut away 20 minute job,thats over a year ago now and no probs, a nice quick 87 degrees,
    hope that helps,i no im not the only one who resorted to the hacksaw
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by greza1066 View Post
    He's right - did mine and cut the bracket off - I undid and disconnected everything I could find connected to it and it was still solid and prevents you taking the threaded stud out, and releasing the bottom half of thermostat housing. Carefully cut through the bracket - its thick stainless steel and you will need an angle grinder to get through it - it doesn' t do any harm - I then removed the stud and cut off the threaded stud turning it into a normal bolt, and will make any future repairs a lot easier. Crap (Fiat) design.
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by tugger434 View Post
    Don't know how you did it with a hacksaw - I tried and it wouldn't look at it
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    Thanks guys, got a quote of £45 to get it changed at a garage so will leave them with the hassle , i thought about cutting the bracket but couldn't fit anything in there
    What a crap design
    ireland
    took me bout an hour with hacksaw,had to break it in half and had about an inch of movement,everytime i hot my knuckles i though of the tit who designed it lol,was gona use a grinder but feared if i slipped what a ****** mess that would be,
    Nov 2010
    East Midlands
    Trim : design
    Your a better man than me if you did it with a hacksaw - I tried and it wouldn't look at it. The other way to do it is cut off the threaded length of stud that goes through the bracket and that leaves you a bolt in the bottom hole of the thermostat flange. Undo every thing you can that is connected to the stainless heat exchanger and then bend the bracket away from the bolt head you have made - undo the bolt and the upper bolt and you should be able to remove the housing with the bottom bolt still in the hole in the flange. when the thermostat is out (have a few beers) you can easily get access to cut the bracket off with a small angle grinder. Fitting the new one without the bracket in place is a doddle
  1. help with thermostat fitting
    By mikey_bates in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd December 2012, 14:36
  2. 1.9 cdti 120 Thermostat Mod
    By no1vic in forum Engine & Drivetrain
    Last Post: 20th February 2011, 21:43
  3. 1.9 CDTI thermostat
    By Ginge7289 in forum Engine & Drivetrain
    Last Post: 27th January 2011, 07:07
  4. New thermostat cdti 150
    By Mikecdti in forum Engine & Drivetrain
    Last Post: 30th April 2010, 16:15
