Thread: Were to take a switched live and a live from for a boost gauge
    Worksop
    Default Were to take a switched live and a live from for a boost gauge
    As above got my maptun boost gauge and pod want to no were easist place to wire it up from and were to take vac pipe to
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Switched live is the black wire on the multi plug going into the back of the dashboard. There's a main earth point behind the drivers side kick panel. The lighting wire goes to the grey with yellow wire on the back of the light switch.
    The hose runs through the bulkhead behind the dash (there's a grommet behind the wiper mechanism under the bonnet, you may need to take the wiper mechanism out, I did as it was easier). You don't say which engine you've got, but if it's the 2.0T, then the connection point is on the vacuum solenoid under the front engine cover, there's a small box with three hoses connected to it and an electrical plug, you cut the hose going to the inlet manifold and place the T-piece in there.
    Regular Member Keif's Avatar
    In the Garage
    I took all my connections from the cigarette lighter, but my Boost gauge is in a centre air vent and has an electrical feed from a boost sensor so no vacuum pipe needs to go through the bulkhead.
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    Yeah, the Maptun gauge has a hose for a vacuum connection not an electrical one. I took the power connections from the closest available point for were I was mounting it.
    My thread were I fitted mine http://www.vectra-c.com/forum/showthread.php?t=137331
    Regular Member benholden2010's Avatar
    Oct 2010
    middlesbrough
    Took my ignition live from multiplug on the back of light switches, it was the closed ignition live I could find, there's also a earth on there too, think the wires were brown and black
    Worksop
    Quote Originally Posted by Ian-Highlander View Post
    It's a 2.0t Ian also how a pillar trim come off
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    i took mine of the ciggy lighter
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    Quote Originally Posted by tomo41 View Post
    Pop the grey pastic clip out at the top and the trim will pull off.
  1. Wot fuses for a live qwn u turn key and a switched live
    By tomo41 in forum Electrical & ICE (including SatNav)
    Last Post: 26th June 2011, 15:15
  2. A note for anyone that needs a switched live for a radio
    By cont1204 in forum Electrical & ICE (including SatNav)
    Last Post: 19th February 2011, 12:18
  3. Stereo switched live
    By andyfeeny in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2010, 12:31
  4. Switched live for aftermarket stereo
    By Mogsy007 in forum Electrical & ICE (including SatNav)
    Last Post: 20th February 2010, 23:41
  5. What colour is the switched live to the headunit?
    By Ziggy in forum Electrical & ICE (including SatNav)
    Last Post: 16th September 2009, 21:45
