Results 1 to 10 of 28
Thread: Ignition live in engine bay
    Sep 2009
    Glasgow
    Default Ignition live in engine bay
    Looking for an ignition live in engine bay, it's to connect some more led strips for either lighting up behind my grill or to light up engine bay in the dark with a switch to turn on and off, not decided yet what i will do, could feed from my led strips that i have fed into the light plugs, but dont want to muck about with that.
    May 2007
    West Yorkshire
    ideal and much less hassle...
    Oct 2006
    southampton
    15 Post(s)
    pretty sure I used fuse 14 in the engine bay for my DRLs....
    Sep 2009
    Glasgow
    12 v led strips, how would i connect this to fuse 14 , is there a fuse already in place and is it a matter of removing it placing the wires down each side of contacts and puting fuse back in, also what is this fuse for. sorry for all the questions.
    Sep 2009
    Glasgow
    dont want to be a pest but hopefully looking to get this done today, anybody any idea on how to run it from fuse 14.
    Oct 2006
    southampton
    15 Post(s)
    two minutes matey,
    I used one of these
    Oct 2006
    southampton
    15 Post(s)
    Quote Originally Posted by nokiaman1978 View Post
    I did just push the live into the slot until the above link arrived HTH...
    Sep 2009
    Glasgow
    thanks mate, where did you connect earth
    Oct 2006
    southampton
    15 Post(s)
    Any earthing point under the bonnet matey, mine are on a switch too so I can turn them off when working on the car and need the ignition on....
    Sep 2009
    Glasgow
    what slot does it go in on fuse 14 left or right mate dont want to blow anything, could you also point out a obvious earth point
  1. Wiring an amp, need an ignition live and permanent live in the boot
    By inchy1981 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2012, 16:36
  2. Alternative ignition live for Parrot to work when engine off, but key still in?
    By Thomza in forum Electrical & ICE (including SatNav)
    Last Post: 10th August 2012, 05:06
  3. ignition live
    By Mads in forum Electrical & ICE (including SatNav)
    Last Post: 12th June 2011, 23:45
  4. Ignition live
    By dazza3674 in forum Electrical & ICE (including SatNav)
    Last Post: 6th May 2011, 20:46
  5. Ignition Live
    By leeds vectra in forum Electrical & ICE (including SatNav)
    Last Post: 4th December 2006, 01:20
