Thread: oil smell
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    Default oil smell
    hi , having a strange problem with my cdti 150 had the oil change last week ever since then keep getting an oil smell when sitting at a junction thought it was oil ran onto exhaust but was all cleaned off been going on for a week now checked no leaks anywhere and breather pipes ok just cant understand why it seamed to start after oil change.
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Quote Originally Posted by paul wingnut View Post
    Hi, might have some oil on the engine block that obviously doesn't get as hot as the exhaust and is burning off a bit slower - usually get more fumes when stationary as the moving air disperses the fumes when on the move. After a run lift your bonnet and you may might be able to see whisps of smoke if it is burning oil. Shouldn't worry too much if there are no visible leaks or pooling underneath
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    i'm with alcutler on this one ,sounds like the mechanic has spilt oil filling the engine,it will have pooled somewere on a flat serface
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Interesting, as I noticed the same after service, also assumed oil on exhaust.
    Regular Member LADmachining's Avatar
    Hampshire
    It will be due to oil on the exhaust flexible joint under the oil filter housing. The Diesel exhaust doesn't get as hot as a petrol engine's one, so it takes a lot longer to burn the oil off.
    Spraying it with a solvent of some sort, such as brake cleaner (whilst cold though, eh? ) will remove the oil and stop the smell.
  1. New car smell
    By marc vectra sri in forum Detailing and Car Care Discussion
    Last Post: 31st July 2012, 21:22
  2. I can smell oil...I think !
    By Nicolas in forum Engine & Drivetrain
    Last Post: 7th October 2010, 07:15
  3. Anybody know to get rid of this smell...
    By bobby-tupper in forum The 'Off Topic' room
    Last Post: 10th April 2009, 09:08
  4. You Smell
    By Lump in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2008, 22:10
  5. bad smell
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 27th June 2008, 21:11
