Results 1 to 10 of 15
Thread: vauxhall vectra big turbo
    Feb 2011
    leeds
    Default vauxhall vectra big turbo
    is there a bigger turbo you can get for a 2.0 turdo
    Regular Member Jezzy's Avatar
    S.E
    What year is your car?
    Feb 2011
    leeds
    54 m8
    S.E
    You've probably got the Garrett turbo, later cars come with the Mitsubishi TD04 which is tougher and will give more power when allied to a remap that takes the turbo change into account; so you could swap to that one.
    Feb 2011
    leeds
    what power will i be looking at m8 and do you know where i will get one
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    Quote Originally Posted by leedslads View Post
    the turbo is a Mitsubishi TD04L14T, it can be found on the later 2006 onwards Vecs and Signums.. The saabs also had them on their B207R engine.. You can buy them reconditioned or straight secondhand from the bay of E or saab breakers.. It has to be a GM version to have correct 3 bolt fitting for your manifold. You can map around 240bhp or more with one of these on, depends on the pother bits you have done and the tuner..
    Regular Member benholden2010's Avatar
    Oct 2010
    middlesbrough
    sorry to hi-jack but im also interested in this.....
    my car is a 55 reg facelift 2.0 Turbo so what turbo will i have?
    i've had the turbo shield off but cant find any markings which state wether its a garrett or mitsubishi
    any way you can tell?
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    you will need to have upgraded your fuel injectors before hand and also bought a new set of oil and water lines to enable you to fit this high pressure turbo. The low pressure Garrett gt2052 you currently have can be mapped up to 230bhp ish depending on your other mods.. This Garrett is very limited in respect of what hybriding can be done to it and not worth doing, a very small return for your money.. its about £130 for new lines, £220 if you buy them from some places.. Siemens 381cc Injectors range from £120 to £170 depending on supplier... Turbos are normally in the £400 plus range. If you don't do it yourself you will need to budget a few hours for labour as well..
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    Quote Originally Posted by benholden2010 View Post
    the Mitsi TD04 is a little bigger but unless you know what your looking for you will need to look at the name plate on the side of the compressor housing, the turbo model number is stamped in there.. I would expect a 55 plate to be a Garrett turbo though but i am unsure from which chassis number they decided to use the Mitsi along with Saab, i am aware from info on here that it was somewhere during or just after 2006..
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    No idea if it'll be of any help but from EPC for Z20NET engines:
    12755106 Turbocharger Assy (Low/Med Output) to 51999999
    to 58999999
    55557611 Turbocharger Assy (Low/Med Output) -11579995 to 11669756
    Superseded by
    55562671 Turbocharger Assy (Low/Med Output) -11579995 to 11669756
    Superseded by
    55564940 Turbocharger Assy (Low/Med Output) - No Chassis range given
  1. vauxhall vectra 2.0 hybrid turbo
    By leedslads in forum Vectra C / Signum Car Chat
    Last Post: 10th February 2013, 13:46
  2. For Sale: Vauxhall Vectra SRi 2.0L Turbo (LPG)
    By Aidi in forum Cars for sale
    Last Post: 10th November 2012, 17:06
  3. VAUXHALL VECTRA C 2.0 TURBO Downpipe
    Last Post: 30th March 2012, 03:13
  4. vauxhall vectra 2.0 turbo pic
    Last Post: 30th March 2011, 21:55
  5. i never really new VAUXHALL VECTRA 2792 cc 2.8 V6 Turbo
    By dannyjpuk in forum Vectra C / Signum Car Chat
    Last Post: 23rd November 2010, 17:53
