Thread: Vectra Cdti transmission oil??
    wolverhampton
    Default Vectra Cdti transmission oil??
    I'm doing a oil change on my gearbox and I'm just wondering how much oil should drain out as I've drained out 5L out of mine is this right as it states in the manual 2.2L should go back in... 1.9cdti 6speed box
    Any help with this matter would be appreciated thanks all :-)
    Regular Member collyb's Avatar
    Mar 2011
    ireland
    the recomendation on this site mate is to put 2.2 back in,,i put 2.5 back into mine,,,but i used cheap grade gearbox oil and to be honest i should have got quality stuff as when my gearbox is cold,,,the gear change notchy between 1st and second,,,but once warm its very smooth,,i also drained around 4.5 to 5 litres from mine
    wolverhampton
    Quote Originally Posted by collyb View Post
    I get a grind from 4th everytime it's selected also when I down shift?
    Mar 2011
    ireland
    Quote Originally Posted by mossy2432 View Post
    well 1st to 2nd on mine rubs a bit,,and also 2nd to 3rd a small bit when cold... but when warm its fine,,i used a semi synth gearbox oil,,,it was a cheap brand,,i guess with quality brands u get smoother changes,,, i tend to try and slip my car into gear anyways when i drive rather than push it,if u know what i mean..
  1. Where can I check the transmission fluid? 04 vectra 3.2 v6
    By fred87nc in forum Engine & Drivetrain
    Last Post: 30th January 2013, 16:37
  2. Vectra C auto Transmission Identification
    By kiwiscole in forum Engine & Drivetrain
    Last Post: 29th September 2012, 13:03
  3. X-tra cooler for transmission oil on V6 CDTi
    By Hummelshøj in forum Vectra C / Signum Car Chat
    Last Post: 14th March 2011, 19:57
  4. help vectra c Transmission Automatic
    By rog3r in forum Engine & Drivetrain
    Last Post: 18th December 2010, 18:43
  5. Automatic Transmission problem in 1.9 cdti
    By devrim in forum Engine & Drivetrain
    Last Post: 25th April 2008, 11:07
