Thread: Heater Control Clicking/Tapping
    Lincs
    Default Heater Control Clicking/Tapping
    Hi, another problem i could do with help please. I've had the heat off all day. Just been out and as i turned the heater control from blue to red a very loud click/tapping comes from behind the glovebox. I stopped turning and sent back to blue, tapping stops.
    Left it for a while, managed to turn from blue to red with no noise......but no heat. Then with a bit more tapping noise, i get heat
    Does something need replacing?
    Ta
    Paul.
    West Sussex
    Quote Originally Posted by pauldellboy View Post
    Ta
    Paul.
    Sounds like a problem I had. This is the info I was given, worth checking.
    I,m afraid you have lost one or more of the teeth on the recirc" servo, it is a common thing on the vectra. Do a search for "air recirc servo" there is a lot of information should you be unfortunate to need it
    Mileage : 000
    Yep sounds like a broken tooth on one of the gears, as said above there is loads of info" on it though.
    Lincs
    Thanks, i've had a read on some of the threads. I'm just not understanding if it's a front or back servo and will i know? Will it start to click continuously and if so can i disconnect anything to stop the noise prior to fitting a new servo? Also when i click on the links that are in the threads, i don't have access. Is that because i am not a full member?
    Paul.
    Lincs
    Any chance of picture so that i know what i'm looking for when i remove the glovebox please.
    Cheers.
  1. Heater clicking noise again
    By Bamber in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd July 2012, 22:40
  2. Weird clicking noise from heater control or glove box
    By rollercoaster63 in forum Electrical & ICE (including SatNav)
    Last Post: 17th November 2011, 14:29
  3. clicking noise (assuming behind heater control pannel)
    By 9tjc in forum Electrical & ICE (including SatNav)
    Last Post: 1st December 2009, 23:11
  4. clicking from behind heater panel. vec-c
    By the-wizard in forum Vectra C / Signum Car Chat
    Last Post: 24th March 2009, 19:55
  5. Clicking / Tapping noise - HELP PLEASE
    By Grantgsi in forum Vectra C / Signum Car Chat
    Last Post: 27th May 2008, 18:15
