Results 1 to 10 of 17
Thread: sub and amp
    East Midlands - Regional Organiser new boy's Avatar
    Nov 2010
    lincs
    80 Post(s)
    Vehicle : Design
    Trim : SRI LEATHER
    Engine : 1.9 cdti
    Year : 56
    confused sub and amp
    Can any one tell me if i can put in a sub and amp useing the standard head unit. ive got a cd30 with no satnav thanks
    Club-Vaux Admin
    Engine : 1.9 cdti
    Mileage : 145k
    If your amp has hi level inputs then yes
    Nov 2010
    lincs
    80 Post(s)
    Vehicle : Design
    Trim : SRI LEATHER
    Engine : 1.9 cdti
    Year : 56
    do i need any thing plugs etc or can plug in head unit.
    Nov 2010
    lincs
    80 Post(s)
    Vehicle : Design
    Trim : SRI LEATHER
    Engine : 1.9 cdti
    Year : 56
    Any one?
    Vectra-sport Admin Dre's Avatar
    Vectra-sport Admin
    Vehicle : VXD
    i took the feed off the rear speaker wires that goes to the connector plug on the loom that goes to the headunit .
    splice in an rca to speaker like this one HERE then connect your left and right phono from your amp to it
    hth
    Oct 2007
    Shropshire
    Yes you can but you will either need to wire the amp to the ignition or have a switch to turn it on as there is no remote switch on lead.
    Also the amp need not have high level inputs you can buy a convertor. If you were closer I would help....
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    Quote Originally Posted by Dre View Post
    hth
    iv done this on my cd70 its easy
    Nov 2010
    lincs
    80 Post(s)
    Vehicle : Design
    Trim : SRI LEATHER
    Engine : 1.9 cdti
    Year : 56
    thanks guys ive got a sub and amp out of my old astra just thinking i mite put it in vec but dont want to change head unit. needed to no wot is involved
    Vectra-sport Admin
    Vehicle : VXD
    i took a live 12v feed from the rear control module in the boot for my amp if your stuck i will have a look and see which fuse location i used , not had any problems with it since fitting it last year
    Nov 2010
    lincs
    80 Post(s)
    Vehicle : Design
    Trim : SRI LEATHER
    Engine : 1.9 cdti
    Year : 56
    Thanks will let u no how i get on.
