Thread: egr mod
    Nov 2010
    doncaster
    Default egr mod
    heard people talk of this egr mod what is it
    Edinburgh
    you can fit a new gasket with smaller hole in it which helps the gases swirl better and therefore less sticks to the valve or you can blank it off completely. If you blank it you either need to leave EGR connected hanging somewhere or have it tech2'd to disable it otherwise you'll get EML.
    Regular Member Kev_G's Avatar
    Jul 2009
    C:\Uk\Chester_North West
    where can you get the smaller hole plate from?
    Edinburgh
    I think most people get it from Fiat (fiat make the engine and released a new gasket I believe, Vauxhall didn't release it) or you can make it if you have the skills. Have a search on here and you'll probably find a fiat part number.
    Nov 2010
    doncaster
    what so you take egr valve off take of od plate put new fiat one on with smaer hole then refit egr is that correct wahts it actually do pros cons
    Edinburgh
    yes pretty much. Unbolt it from manifold, remove old gasket, probably give the EGR a clean since its off anyways, refit it new modded gasket. probably 20 minute job.
    Pros - EGR less likely to jam as carbon less likely to stick in theory
    Cons - none that I'm aware of, it was designed for the vehicle by manufacturer. If you make your own, you have to make the whole big enough so there is enough flow but as small as possible to keep as much carbon out as possible.
    Photos here:
    http://www.vectra-c.com/forum/showpo...1&postcount=19
    Top - existing gasket
    middle - modded gaskey
    Nov 2010
    doncaster
    are these pics for a 1.9 cdti 150 16v cause i have seen gaskets that are oval with one hole in middle
    Regular Member CH-VECTRA-ELITE's Avatar
    Frimley
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 140000
    Have a look at this thread,
    http://www.vectra-c.com/forum/showth...t=48513&page=5
    I'll be going to fiat to order the parts when i get back from my holiday, and then crack on with the job, my car is fine at the moment but some days it does lack performance so a good clean can't hurt.
    Fiat part numbers
    0055226183 SEALING GASKET at £2.20 (stock item)
    0055225287 SEALING GASKET at £4.67 (non-stock item)
    plus 20% VAT = £8.24 total
