Results 1 to 10 of 14
Thread: Changing fuel filter
    Regular Member Kev_A's Avatar
    Gateshead, Tyne and wear
    Engine : Z20NET
    Default Changing fuel filter
    Planning on changing my fuel filter & spark plugs this weekend, can anyone tell me how to go about the fuel filter? It's a 2.0 T btw
    WGAF#5
    its mounted under the rear near the osr wheel in line with the body
    it has a little clip front and rear to release the snap fits these are a pain but can be accomplished with a small screwdriver
    if you dont clamp the pipes before and after the filter expect some fuel to be spilled/sprayed if the sytem is still under pressure so have some rags handy
    the filter will then slide out of its holder - make sure you reinsert the new filter with the arrow flowing from the tank to the front of the car reconncet the snap plug and hey presto job done
    Regular Member jimmyred's Avatar
    Dec 2010
    Southport
    You can depressurize the fuel system, there will be something looks like a bicycle tyre valve on fuel rail, beneath engine cover. Just press the valve with a rag over it to soak up the squirt.
    You are best using needle nose pliers to undo the clips. I struggled with mine a while. Its worth having a couple of small jubilee hose clips handy, in case you damage them getting old one off. I did!
    Other than that just make sure you have it right way round. Fuel flows from back of car to front.
    I put rear of car on axle stands. It might be possible to do it with car on ground. Don't put your head underneath a car only supported by jack.
    Engine : Z20NET
    Ok, cheers for that, what do you use to clamp the lines either side of the filter?
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    If you have not run the car for a couple of hours then there will be no pressure so no need to clamp the pipes.
    Dec 2010
    Southport
    well if the system is depressurized there won't be much spillage...most comes out of the old fuel filter anyway. I suppose you could use anything like mole grips or even strong clothes pegs.I'd be more worried about damaging fuel lines, mind you I expect they are made pretty tough. I didn't bother clamping them, you might use an old plastic ice cream tub to catch old fiiter in, cos the stuff that comes out of it is filthy!
    Engine : Z20NET
    That was going to be my next question lol, car will be cold, parked under the building, going to do the plugs and filter as they're the only serviceable items not changed in the 3 months I've had the car
    Oh Nige, spoke to Nicholas @ Neo bros, he said the '06 Vectra T they bought is now in Sweden with Maptun and when it returns it should be running circa 300bhp, they said the will then be offering a 6 stage tuning program for us "Z20NET" owners
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    good news.. I will be speaking with him today to buy a couple of new coils for mine..
    The fuel filter is easy as they say, i got fuel in my face though from the fuel held in the filter... watch out for that lol
    Engine : Z20NET
    Will do mate
    That'll be the last of the service stuff for a while I hope!
    Got a little bit of paintwork to sort then it'll be onto tunint I think, going to get it RR'd first then go with a turbo back exhaust and sports cat
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    cool... tune the t1ts off it mate.. there great
  1. HELP!! after changing fuel filter
    By williamM in forum Engine & Drivetrain
    Last Post: 30th December 2010, 17:49
  2. changing the fuel filter on a DTI
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 10th August 2009, 12:30
  3. Changing Fuel Filter
    By Sean-2.2Direct in forum Engine & Drivetrain
    Last Post: 22nd April 2009, 10:21
  4. Changing Fuel Filter
    By davieboy1976 in forum Vectra C / Signum Car Chat
    Last Post: 15th April 2009, 11:41
  5. Changing Fuel Filter
    By CDTi-SRi-Matt in forum Engine & Drivetrain
    Last Post: 8th February 2009, 17:36
vectra c 2.0 Turbo fuel filter
vectra sri fuel filter change
vectra 2.2 direct sri fuel filter change
vectra c 2.0 dti fuel filter change
vectra 2.0 dti fuel filter change www.vectra-c.com
Change fuel filter 2.2 direct
vauxhall 2.2 direct fuel filter
vectra c diesel fuel filter change dti
