Results 1 to 3 of 3
Thread: Help with locating something...
    Aug 2010
    Stoke on Trent
    Default Help with locating something...
    Look at the image below... the red box is a connector for ABS & TPMS rear axle wiring.
    If you follow the wire back from the red box and back past X10 to the right it goes through a gromet.
    I need to locate that gromet... can anyone locate it for me from either under or inside the car as I can't seem to find it.
    Admin plasma's Avatar
    On the Forum
    265 Post(s)
    Engine : 150
    Mileage : 74000
    The route it takes is above the fuel tank and then in through underneath the rear bench seat.. The x10 plug is underneath the car and fairly easy to disconnect if a bit mucky....
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Aug 2010
    Stoke on Trent
    Thanks for that... my extra TPMS wiring needs to follow this route.
  1. locating stater motor bearings cdti 150
    By dave r in forum Diesel Engine related
    Last Post: 21st September 2011, 14:42
  2. Locating a speed signal
    By signum_rob in forum Electrical & ICE (including SatNav)
    Last Post: 23rd December 2010, 18:43
  3. Help locating a thread with a home made aux in socket
    By lofty in forum Vectra C / Signum Car Chat
    Last Post: 9th May 2010, 19:03
  4. locating boost sensor
    By nigec in forum Engine & Drivetrain
    Last Post: 23rd March 2010, 22:39
  5. Help locating my old car
    By videodoctor in forum Vectra C / Signum Car Chat
    Last Post: 23rd April 2007, 19:49
