Thread: Passenger seat wont move!!!
    Regular Member edwardabud86's Avatar
    Aug 2009
    luton
    Default Passenger seat wont move!!!
    Hi all,
    I had the car washed inside and out today, and they moved the seat forward to hoover behind it. And when i went to move it back to its original postion it something broke!!!
    And now the little leaver moves but the chair doesn't!
    Has anyone experienced this problem and is it an easy fix??
    Kind Regards
    Ed
    Full Member
    South West
    Had it with mine a few weeks back.
    When you pull the lever to make it move, it pushes down on a small plunger in the sliding rail, which allows the seat to move.
    The plunger had somehow become stuck on mine, so it was a case of getting a large flathead screwdriver in there and wiggling around until the plunger spring back into position.
    Would have been a great deal easier if the seat had been removed, but it wasnt an option for me at the time. If you can remove the seat (very easy to do) it will make it much easier to figure out what is not working correctly.
    It could also be that the bit of metal which pushes down on the plunger had become mis shaped and not making contact, or the cable has stretched or become detached.
    Rgds
    Aidi
    Aug 2009
    luton
    oh ok, Cheers Aidi. I shall have a look tomorrow. Or perhaps i'll leave it a couple of days so i can enjoy watching the mrs with her knees up on the dash! haha
    i put money on the cable just coming loose from its housing
    pump the height of the seat up and then you will able to see what i mean
    Regular Member jimmyred's Avatar
    Dec 2010
    Southport
    The lever at front pulls a cable similar to the brake cable on a bicycle. This is anchored at other end on a spring loaded axle that has levers that wedge on the track, holding seat in place. When you pull handle, the cable pulls and twists axle, lifting levers allowing seat to move. Have a look in rear footwell at working mechanism on other seat.
    As Mark Taylor says, the little noggin that attaches cable to axle has probably popped out. It should just slot back in. However, mine had snapped off the end of the cable. If this is the case a new cable is less than a tenner. I thought it would be fiddly to fit, so I came up with a jury rig fix:
    Using the 2 part resin ''super putty'' you can get from DIY shops, I rolled a pea size piece. I then squidged it onto the end of the wire, working it in well. I then shaped it with my fingers into a teardrop shape. When this dried it worked perfectly to attach cable to mechanism.
    In the mean time you can operate mechanism by hand by reaching under seat from rear footwell.
  1. omega wont move
    By chris1804 in forum General Motoring Chat
    Last Post: 7th April 2012, 16:04
  2. passenger seat jammed right back on runners and wont budge!
    By richiem in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2011, 22:28
  3. RE:- car wont move.
    By davieboy1976 in forum Vectra C / Signum Car Chat
    Last Post: 8th November 2009, 21:09
  4. HELP car wont move !!!
    Last Post: 4th November 2009, 17:06
  5. Signum passenger seat wount move??
    By kenno31 in forum Bodywork & Interior
    Last Post: 22nd May 2008, 08:50
