View Poll Results: 2 stroke oil or Additive
Voters
29. You may not vote on this poll
  • 2 stroke oil
    21 72.41%
  • additive
    11 37.93%
Multiple Choice Poll.
Results 1 to 10 of 19
Thread: 2 stroke oil or real additive
    Regular Member smirnoff sri-dti's Avatar
    Apr 2011
    London
    Default 2 stroke oil or real additive
    what you pips think of the choice between
    £10 Oil 2 stoke
    or
    £10 Diesel Additive
    for example we will say it will be both from Halfords
    so good stuff but what will you go for ?
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I voted both
    Regular Member andy-j's Avatar
    Apr 2008
    stoke on trent
    I vote neither, the engine is designed to run on pure diesel.
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    No opinion, yet. If I use cheap diesel I usually put some additive in, been reading about the 2 stroke oil, not tried it.
    Regular Member zafira's Avatar
    Aug 2010
    North of Norway
    I use 2 dl 2-stroke oil every 40-50 liter of diesel. This lubricate the pump and injectors. Engine run more smoothly and is less noise.
    Of course todays diesel engine run fine without 2 stroke oil or other stuff in the diesel. But when oil company stop adding sulfur in diesel lubricating of the pump and injectors become a problem. And car manufactors has used different solutions to solve this problem with special treatment of the diesel system. But there is no doubt, 2 stroke oil give you more miles before pump and injectors need to be change and less noice from the engine.
    Apr 2011
    London
    so tell me if i am wrong
    pips mixing oil with oil and telling me its better then just oil on its own
    wirral
    36 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    I've not tried 2 stroke yet.
    Tried some redex advance on the last tank an car ran better. An I got an extra 2.5 mpg.
    Not very much no but Excactly the sane journey I do every sunday night an same speed and all I was after was cleaning fuel system out so from that I'm guessing it must work even if only slightly. Am goin to use another bottle of redex an then try 2 stroke and see if Theres any difference
    Regular Member mcpitman's Avatar
    May 2011
    Derby
    Trim : Club
    Engine : 1.9 CDTi
    Currently use Millers additive, but tempted to give 2 stroke a chance.
    I have only just bought the car, so i was going with the theory of Millers to clean it, 2 stroke to lubricate after that.
    Regular Member sdemps's Avatar
    Nov 2007
    Ayrshire
    2 stroke is £4.50 from tesco or asda this does 3 - 4 tanks.
    Regular Member Innes's Avatar
    Plymouth
    I've been running 2stroke for 4 tank fulls. It quietend down the engine and got 2mpg more. I have recently found a bottle of Redex in the garage that I had forgotton about which I thought i'd try and see if I can see the difference btween the two. I'm on the last tank of Reddex and to be honest I havent noticed much difference. Maybe a little louder on the reddex but not much.
    For the cost i'd go with the 2stroke.
    Quote Originally Posted by smirnoff sri-dti View Post
    In 2006 the fuel companys removed more sulpher from their diesel. Sulpher lubricated the fuel pumps and the rest of the fuel system. Its of more benefit to us DTI owners as the 2stroke will prolong the life of the fuel pump as well as keep everything running smoothly. From what i've read more modern cars fuel pumps have things like teflon coated parts to take into account the loss of lubricant from the sulpher.
  1. bg224 additive
    By wildchild in forum General Motoring Chat
    Last Post: 19th February 2013, 21:51
  2. What Fuel Additive Is Best?
    By adierolfe in forum Engine & Drivetrain
    Last Post: 11th June 2012, 20:38
  3. Screenwash additive?
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2010, 17:32
  4. Oil additive
    Last Post: 3rd October 2010, 22:19
  5. which diesel additive
    By wardy in forum Vectra C / Signum Car Chat
    Last Post: 10th November 2009, 20:43
2 stroke running in vectra c
