Results 1 to 10 of 13
Thread: Changing The Size Of The Wheels.
    Regular Member Vectra Bear's Avatar
    May 2011
    Southampton
    Default Changing The Size Of The Wheels.
    Hi there,
    I'm looking to get bigger wheels/tyres on my 57 plate vectra estate in black, and I wondered what size I could go up to, I will look myself of course, but I thought I'd post on here to see if anyone had a idea, I'm not sure if it's all of this type of car, but it seems to be quite low to the ground.
    Any help would be much appreciated.
    Lew.
    Regular Member Vectra_C_Chris's Avatar
    Perth Western Australia
    What model is it?
    SRi, GSi, CDTi?
    The SRi and GSi are lower than the other models, bar VXR. (Not sure what the plate number relates to regarding year of model )
    I went 19" on my 2003 GSi, had no problems with scrubbing or any of that.
    19" snowies lowered 30mm on Eibach springs
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    i had 20in chromes and nuffing was a signum tho
    Regular Member PANDY 3.2 V6's Avatar
    sunderland
    Won't be a gsi on a 57 plate. 19s will be fine apart from poor ride quality. Twenties will only be ok if you put rubber bands on them
    New Member Tmd's Avatar
    May 2011
    UK
    Only thing to consider is the gearing will be changed. Larger wheels = higher top speed but less acceleration, smaller wheels gives the opposite more acceleration but lower top speed. Less torque is required to move smaller wheels so you accelerate quicker. I am no physicist (can't even spell it) but I am basically correct.
    Regular Member Jezzy's Avatar
    S.E
    Quote Originally Posted by Tmd View Post
    Not entirely applicable, because when you increase the wheel diameter you also reduce the tyre profile to compensate, hence 17" wheels and 215/50 tyres have pretty much the same overall circumference as 16" wheels and 215/55 tyres. That's why when you fit 19" snowflakes, you don't use 50 or 55 section tyres, you use 35 section.
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Im running 20's on my estate on 30mm drop eibachs
    Pics on here http://www.vectra-c.com/forum/showthread.php?t=137676
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    He has a design acording to his profile, so lowered 15mm from standard. anything up to 20's will be fine with correct tyre profile
    May 2011
    UK
    Yes you're right as long as your tyre is thinner to compensate then no effect. Some people go from 16" wheels to 19" rims and so that's 75mm of profile to reduce to compensate - so it will be a raise in gearing in a lot of cases be it slightly.
    Aug 2010
    Stoke on Trent
    I've found that in general when I've put bigger wheels on my cars for example 17" to 19" the fuel economy has decreased by as much as 10%.
  1. Views of changing Tyre size.
    By mally in forum Handling & Braking
    Last Post: 5th September 2011, 12:42
  2. 19" Snowies - Changing Tyre Size (& Getting Rid of Space Saver)
    By DanR in forum Suspension, Wheels & Brakes
    Last Post: 12th December 2010, 00:01
  3. Maybe changing my wheels
    By Big-Pete in forum Styling
    Last Post: 10th April 2009, 20:36
  4. when changing to the alternative size 17" tyres...
    By mark_w in forum Vectra C / Signum Car Chat
    Last Post: 27th February 2009, 18:38
  5. Changing Tyre Size
    By philzi in forum Handling & Braking
    Last Post: 4th October 2005, 12:21
