Thread: electric window /central locking not working
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Default electric window /central locking not working
    Hi Guys my turn to ask for help this time,drivers door central locking stopped working,all other doors ok,also electic window not working,but can open/close passenger window and rear windows from drivers door console,drivers door locks ok with key.2003 Signum Dti
    Jul 2009
    Engine : 20 Dti
    OK sorted
    Oct 2009
    BANGOR,N.IRELAND
    Quote Originally Posted by jonnybravo View Post
    OK sorted
    Hi mate, can you give me an idea on how you fixed it? Same problem happened to me this morning. Cheers
    Jul 2011
    Same problem with my Vectra 2.2 Elegance. Drivers door doesn't unlock with key fob. Drivers electric window doesn't work and mirror adjustment also. Drivers console works all other passenger windows, passenger side electric mirror, rear boot release and central locking except drivers door. Checked fuse 5 door module control unit, fuse 15 drivers door control unit & fuse 8 control unit front passenger door module. All OK. Took plug apart in door opening and sprayed with WD40 with no result. Out of ideas now. Anyone help?
    Jul 2011
    Godson, who is a mechanic, came round tonight and said it must be a broken wire. Pulled the rubber gaiter back from the plug in the door closure & lo & behold a broken red wire. Tricky part now is the re-join with the other end that we can't see. He's back Friday with hopefully a solution. Might mean door coming off to get access. Watch this space
    Jul 2009
    Engine : 20 Dti
    Hi jonny,it's a long time since my signum had the same problem I slit the rubber gaiter almost full length and joined the broken wire with a short length of new wire and plug in wire connectors.resealed the gaiter with evostik no problem since
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    If you must slit your gator, I would recommend CV boot glue - much more durable
    Also -could I recommend that you get a spare wire from a scrap vehicle...
    The pins can be extracted from the door connector quite easily, using a small jewellers flat screwdriver - say with a 1.4mm wide flat blade.
    Cut a donor piece of wire longer than you need to pass from the connector, through the door frame.
    Saves soldering the wire, where it will be flexed in future.
    Jul 2011
    Thanks guys. Godson came round tonight and cut a small piece out of gaiter and fished around to find the other broken end, Soldered wires together then fed new cable down the gaiter and attached to the other end. Taped over cut piece. I'll keep an eye on that to make sure no water gets in.
    Jan 2016
    Gateshead
    Trim : Cdi
    Engine : 2.2 petrol
    Default Central locking@driver windowjo
    Quote Originally Posted by JonnyParsnips View Post
    Hi Jonny
    was the broken wire at the door module plug
    i,m having exactly the same problem with my 2.2 vectra
    cheers Col1509
    Wirral / ellesmere port
    12 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    no the common broken wires are in the rubber boot that goes
    between the door and the body pillar
  1. Central locking fob only working inside the car
    By chunkey_monkee in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2012, 22:51
  2. Rear door - No electric window or interior light but Central Locking working!
    By siw8158 in forum Electrical & ICE (including SatNav)
    Last Post: 25th February 2011, 23:41
  3. central locking door button stopped working
    By MURDO in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2011, 22:47
  4. Central Door Locking not working after disconnecting battery
    By onlymeagain in forum Electrical & ICE (including SatNav)
    Last Post: 18th March 2010, 10:06
  5. Central locking not working
    By BaileySRI in forum Electrical & ICE (including SatNav)
    Last Post: 14th February 2010, 11:00
vectra c window fuse
vectra c central locking not working
central locking not working on vauxhall vectra
vauxhall vectra electric window fault
vectra c control box on drivers door
vectra dri
2005 vectra drivers door central licking not working
vectra central locking problems
vectra electric window fuse
Vauxhall vectra central locking faults
my Opel vectra c central lock not working
does vectra have fuse for passenher elcetric wondow
windows and central locking not working vauxhall corsa
vectra c central locking control unit
central locking not working vauxhall vectra
opel vectra passenger electric dont.work
https:www.vectra-c.comforumshowthread.php138061-electric-window-central-locking-not-working
vectra c drivers electric locking not working
vauxhall signum electric windows wont work on 3 doors
what fuse in the windows vauxhall omega
opel vectra b central lock and windows not responding
which is the fuse for the drivers door lock vaxuhall vectra
all electrics on one door not working opel corsa
opel vectre 05 driver window fuses
vectra c door module control unit
