Thread: Black smoke at high revs ?????
    Regular Member collyb's Avatar
    Mar 2011
    ireland
    Default Black smoke at high revs ?????
    well lads and lassies , i dont really drive my vectra hard at all but today i took the it for a good country side blast and noticed that a higher revs it send out a good cloud of blackish smoke from exhaust,,,,,,, any body any ideas ?? she has only been serviced 1000mile ago and ive cleaned egr and boost sensor about 500miles ago
    Regular Member wingz123's Avatar
    Mar 2011
    M4 Junc 12
    bro mine used to smoke like anything when i got it and it was an ex-taxi. Since buying it i do alot of motorway mileage and i sit at 90ish and i tell you something mate - no where near as much black smoke as when i first had the car.....
    mine does need a service desperately which i will try and do soon and that should clear up the last of it...
    if you are using fully synthetic oil in your that could be a cause of a little bit of it as fully synthetic can sometime be a bit heavy in diesels and so produces a bit of soot/black smoke....
    hope that helps in someway
    north east
    How high were the revs ?
    Blac smoke one a diesel isnt a problem its probably just al sooted up and needed a good blst out. blue smoe is what you worry about.
    Excessive black smoke at low revs = intecooler plumbing has hole somewhere.
    Regular Member skip85's Avatar
    Wiltshire
    Vehicle : vectra c estate
    Engine : 1.9 cdti 150
    Mileage : 150000
    Quote Originally Posted by roswell View Post
    And a dose of redex!!! With decent fuel, not supermarket crap!
  1. high revs
    By andy_richmond in forum Engine & Drivetrain
    Last Post: 12th October 2012, 18:43
  2. Black exhaust smoke on high revs, EGR light on, rough idles - 1.9 cdti 150 diesel
    By bananas in forum Vectra C / Signum Troubleshooting
    Last Post: 5th September 2012, 13:25
  3. high revs when hot
    By mentor in forum Engine & Drivetrain
    Last Post: 26th May 2011, 12:36
  4. Signum 120 CDTi black smoke and loss of power @ low revs!!!!
    By siw8158 in forum Engine & Drivetrain
    Last Post: 29th July 2010, 17:08
  5. Car and spanner after high revs
    By Chuddy in forum Engine & Drivetrain
    Last Post: 7th February 2010, 14:50
