Thread: Glow plug fault
    Regular Member Jekyll & Hyde's Avatar
    Walderslade Woods,Kent.
    Default Glow plug fault
    I’ve had the spanner light up for the last couple of weeks. I checked it using my knocked off opcom, & got the following fault code Po380-08 (Glow device general error).
    When i plugged in the op-com it was reading from cold.
    Exhaust gas temp bank 1 sensor 1
    88 degrees
    1 volt
    Exhaust gas temp bank 1 sensor 2
    46 degrees
    0.9volts
    After a few minutes of the engine just ticking over it read the following:
    100 degrees
    1 volt
    84 degrees
    1 volt
    I’ve changed the glow plug relay, the fault is still present.
    Checked the glow plugs for resistant’s, & supply to the plugs, this was done with the car hot as i had to do a few things, & go round to my parents as i needed another pair of hands to turn the ignition on & off to do the test.
    Voltage
    Cylinder 1 728 Ohms 1.2 Volts
    Cylinder 2 0.6 Ohms 1.2 Volts
    Cylinder 3 175 Ohms 1.2 Volts
    Cylinder 4 0 Ohms 1.2 Volts
    Looking at the above i would say i have two plugs that are knackered, can someone confirm this?
    Also if they are knackered, what make are the glow plugs fitted to the car?
    If there Bosch, then there is no listing for it in their parts catalogue, or any Vauxhall/Opel
    Robert
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    yep, looks like two duffers to me... I have the exact same fault so need to check mine as well.
    You might not want to mention op-com
    West
    If i were you i would just replace all 4, it will save you going back & doing the other 2 in a short while
    Yeh thought they were shot.I would change all four & keep the two ok ones for a raining day.
    What are the make & part number of the glow plugs?
    Dec 2010
    wirral
    is opcom a birty word?
    Regular Member LADmachining's Avatar
    Hampshire
    Quote Originally Posted by woodspsx1 View Post
    It is when you mention using a knocked-off pirated version.
  1. Spanner light glow plug fault
    By drewdrewuk in forum Engine & Drivetrain
    Last Post: 25th January 2013, 12:53
  2. glow plug general fault.
    By woodspsx1 in forum Engine & Drivetrain
    Last Post: 7th April 2011, 07:53
  3. glow plug fault?
    By wilbur1 in forum Engine & Drivetrain
    Last Post: 10th February 2011, 19:00
  4. Glow plug removal + elec fault
    By mr.c72 in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2010, 22:23
  5. 2.0 dti glow plug fault???
    By 3.0cdti-taxi in forum Engine & Drivetrain
    Last Post: 16th May 2009, 09:24
