Thread: eibach part no.
    Regular Member mrk's Avatar
    Vehicle : vectra hatchback
    Trim : improving
    Engine : 1.9cdti mas remap
    Year : 06
    Default eibach part no.
    for the 1.9cdti there are 2 sets listed on the euro car parts site just wondered which to order the ones ending with 111 or 121 as they appear the same bar the weight rating(its a hatchback if it makes a difference)
    cheers
    Regular Member djr69uk's Avatar
    Midlands
    if you have a 150 then your axle weight is about 1065 i think.... basically just over the limit of the first set. however, because you are only just slightly over if you go for the higher weight set, your car might sit a bit higher than you would be expecting. because of that people have fitted both types. if you want lower go for the lower weight rated springs.
    Trim : improving
    Year : 06
    cheers m8
    hERTFORDSHIRE
    also was wondering this thanks...
  1. CDTI 150 Estate Eibach Spring Part Numbers
    By Betty in forum Suspension, Wheels & Brakes
    Last Post: 6th November 2012, 13:13
  2. B12 Pro / B8+Eibach Part number confirmation for CDTI 150
    By muad_dib77 in forum Handling & Braking
    Last Post: 4th October 2012, 17:35
  3. eibach part number
    By mrk in forum Handling & Braking
    Last Post: 13th January 2012, 14:54
  4. Which Springs, Eibach part no?
    By Carmaduk in forum Handling & Braking
    Last Post: 2nd June 2011, 13:48
  5. Bilstein / Eibach part No check
    By grattygruff in forum Handling & Braking
    Last Post: 28th September 2007, 15:29
